* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 17 | -0/+17 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Sort source lists | Sebastian Huber | 2021-02-24 | 1 | -1/+1 |
| | | | | Use the Python sorted() function to sort the "source" lists. | ||||
* | bsps: Use header file for GIC architecture support | Sebastian Huber | 2020-12-23 | 1 | -1/+0 |
| | | | | | | This avoids a function call overhead in the interrupt dispatching. Update #4202. | ||||
* | bsps: Move ARM GICv2 driver to bsps/shared | Kinsey Moore | 2020-12-02 | 1 | -1/+2 |
| | | | | | This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64 code. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 19 | -0/+425 |
Update #3818. |
