Add the BSPs for running on the ZU3EG Ultrascale+ Zynq MPSoC and alter
the option defaults necessary for them to run properly using the
standard BOOT.BIN configured for PetaLinux that comes in the Out-of-Box
package.
Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
Updates #4321
Updates #4320
This enables several testsuites that were initially disabled during
development.
The current ZynqMP BSPs don't have _qemu in their name as do all other
RTEMS BSPs that are specifically made to run on QEMU. This fixes the
naming for those ZynqMP BSP variants for easier identification.
Remove usage of SUBALIGN() in aarch64 linkcmds which works around a
difference in behavior on AArch64 platforms. This is no longer necessary
since alignment is now enforced explicitly.
Closes #4178.
Closes #4179.
Update #4267.
Use the Python sorted() function to sort the "source" lists.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Currently, zynq-uart code is always built and has some requirements for
BSPs that use it. Instead of making all BSPs satisfy that requirement or
working around it by setting defaults, this moves the zynq-uart code
into its own spec build object so it can be included if needed.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
