This adds a BSP variant for the ZynqMP BSP family to support the
Innoflight CFC-400X platform. To properly support the CFC-400X, device
trees were added to the ZynqMP platform due to both the optional
management interface as well as alternate physical configuration of the
ethernet interfaces.
Updates #4705
This moves the AArch64 MMU memory type definitions into cpukit for use
by libdebugger since remapping of memory is required to insert software
breakpoints.
ARM's GICv2 is configurable and its attributes vary between
implementations including omission of specific interrupts. This allows
BSPs to accomodate those varying implementations with customized
attribute sets.
Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
Update #4267.
Use the Python sorted() function to sort the "source" lists.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This adds an AArch64 basic BSP based on Qemu's Cortex-A53 emulation with
interrupt support using GICv3 and clock support using the ARM GPT.
