path: root/scripts (follow)
* Patch rtems-rc-19991105-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-161-1/+6
| | | | | | | This is the gdb.spec.in fix patch: * install infos gzip-ed * add gdb to group rtems
* Removed.Joel Sherrill1999-11-051-249/+0
* Added this file as a way to build RPMs for CPUs that would onlyJoel Sherrill1999-11-051-0/+174
| | | | | successfully build C/C++ and not all of the other languages included in late model egcs/gcc releases.
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-044-47/+19
| | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
* Added first stab at mkgnatnewlib.Joel Sherrill1999-11-046-0/+692
* Fixed typo.Joel Sherrill1999-11-021-1/+1
* Clean up /opt/rtems in case junk is installed in the wrong place.Joel Sherrill1999-11-021-4/+4
| | | | This has been seen on some machine configurations.
* Latest version from Ralf Corsepius <corsepiu@faw.uni-ulm.de> whichJoel Sherrill1999-10-271-44/+103
| | | | splits gcc, gcj, chill, f77 and objc into separate rpms..
* Removing automatically generated files.Joel Sherrill1999-10-264-1088/+0
* Removed generated file.Joel Sherrill1999-10-261-1101/+0
* New versions for gcc and patch.Joel Sherrill1999-10-261-2/+2
* RegeneratedJoel Sherrill1999-10-266-27/+34
* Patch generated from scripts-19991025-0.tar.gz fromJoel Sherrill1999-10-2510-74/+143
| | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages)
* Regnenerated following update from Ralf.Joel Sherrill1999-10-256-27/+34
* Merged scripts-19991022-0 changes from Ralf.Joel Sherrill1999-10-2510-122/+82
* Changed version number.Joel Sherrill1999-10-251-1/+1
* Now builds RPM without complete source. Each target is only 15K.Joel Sherrill1999-10-216-9/+59
* Made the RTEMS version get substituted properly even though it isJoel Sherrill1999-10-2114-9/+27
| | | | | | not right yet. Now can specify rpm_build_root via setup.
* Now can specify rpm_build_root via setup.Joel Sherrill1999-10-211-2/+2
| | | | Changed package name so generated RPM would have a nicer name.
* Added sh-rtemself and m68k-rtemself.Joel Sherrill1999-10-2110-143/+176
* Changes from Ralf with script-19991021-0. He fixed the %filesJoel Sherrill1999-10-2119-135/+231
| | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process.
* Shipping this all to Ralf.Joel Sherrill1999-10-212-6/+7
* Moved stuff to rtems subdirectory and made sure the system stillJoel Sherrill1999-10-207-19/+42
| | | | functioned.
* Moved stuff to rtems subdirectory and made sure the system stillJoel Sherrill1999-10-202-34/+37
| | | | | | functioned. Merged Ralf's changes into gccnewlib.spec.in.
* New file.Joel Sherrill1999-10-201-0/+50
* Miscellaneous improvements and cleanups committed so I can mergeJoel Sherrill1999-10-2013-199/+35
| | | | Ralf's end of day version.
* Moved rtems specific files into here.Joel Sherrill1999-10-201-0/+80
* Moving things to an rtems subdirectory like the other tools.Joel Sherrill1999-10-202-80/+0
* New file.Joel Sherrill1999-10-201-0/+177
* Added RPM release numbers.Joel Sherrill1999-10-202-10/+25
* Generated files removed.Joel Sherrill1999-10-2011-307/+155
* Obsoleted.Joel Sherrill1999-10-201-34/+0
* Obsoleted as they were distributed to subdirectories.Joel Sherrill1999-10-204-473/+0
* Made this more binutils like. :)Joel Sherrill1999-10-201-5/+9
* New file.Joel Sherrill1999-10-201-0/+104
* New files.Joel Sherrill1999-10-202-0/+285
* Adding the infrastructure for gdb.Joel Sherrill1999-10-2010-47/+155
* Corrected typo.Joel Sherrill1999-10-201-3/+3
* Restored joel's changes after merging old version from Ralf.Joel Sherrill1999-10-201-19/+90
* New version from Ralf.Joel Sherrill1999-10-2028-213/+3357
* Committing changes before Ralf's changed.Joel Sherrill1999-10-204-24/+92
* Left to build overnight.Joel Sherrill1999-10-197-10/+123
* Made it easier to change version numbers.Joel Sherrill1999-10-192-15/+21
* Now easier to modify version numbers in scripts.Joel Sherrill1999-10-192-14/+20
* Easier to insert tool version number.Joel Sherrill1999-10-192-20/+31
* Making sparc-rtems rpms available.Joel Sherrill1999-10-183-2/+3
* Working on being able to cut RPMs. It now appears that the processJoel Sherrill1999-10-1812-27/+788
| | | | | | | | | | | | | is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets.
* Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts toJoel Sherrill1999-10-157-0/+399
help build RPMs.
