1999-11-16 | Patch rtems-rc-19991105-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -1/+6 | |
This is the gdb.spec.in fix patch: * install infos gzip-ed * add gdb to group rtems | |||||
1999-11-05 | Removed. | Joel Sherrill | 1 | -249/+0 | |
1999-11-05 | Added this file as a way to build RPMs for CPUs that would only | Joel Sherrill | 1 | -0/+174 | |
successfully build C/C++ and not all of the other languages included in late model egcs/gcc releases. | |||||
1999-11-04 | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 4 | -47/+19 | |
particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
1999-11-04 | Added first stab at mkgnatnewlib. | Joel Sherrill | 6 | -0/+692 | |
1999-11-02 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
1999-11-02 | Clean up /opt/rtems in case junk is installed in the wrong place. | Joel Sherrill | 1 | -4/+4 | |
This has been seen on some machine configurations. | |||||
1999-10-27 | Latest version from Ralf Corsepius <corsepiu@faw.uni-ulm.de> which | Joel Sherrill | 1 | -44/+103 | |
splits gcc, gcj, chill, f77 and objc into separate rpms.. | |||||
1999-10-26 | Removing automatically generated files. | Joel Sherrill | 4 | -1088/+0 | |
1999-10-26 | Removed generated file. | Joel Sherrill | 1 | -1101/+0 | |
1999-10-26 | New versions for gcc and patch. | Joel Sherrill | 1 | -2/+2 | |
1999-10-26 | Regenerated | Joel Sherrill | 6 | -27/+34 | |
1999-10-25 | Patch generated from scripts-19991025-0.tar.gz from | Joel Sherrill | 10 | -74/+143 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages) | |||||
1999-10-25 | Regnenerated following update from Ralf. | Joel Sherrill | 6 | -27/+34 | |
1999-10-25 | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 10 | -122/+82 | |
1999-10-25 | Changed version number. | Joel Sherrill | 1 | -1/+1 | |
1999-10-21 | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 6 | -9/+59 | |
1999-10-21 | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 14 | -9/+27 | |
not right yet. Now can specify rpm_build_root via setup. | |||||
1999-10-21 | Now can specify rpm_build_root via setup. | Joel Sherrill | 1 | -2/+2 | |
Changed package name so generated RPM would have a nicer name. | |||||
1999-10-21 | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 10 | -143/+176 | |
1999-10-21 | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 19 | -135/+231 | |
issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | |||||
1999-10-21 | Shipping this all to Ralf. | Joel Sherrill | 2 | -6/+7 | |
1999-10-20 | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 7 | -19/+42 | |
functioned. | |||||
1999-10-20 | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 2 | -34/+37 | |
functioned. Merged Ralf's changes into gccnewlib.spec.in. | |||||
1999-10-20 | New file. | Joel Sherrill | 1 | -0/+50 | |
1999-10-20 | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 13 | -199/+35 | |
Ralf's end of day version. | |||||
1999-10-20 | Moved rtems specific files into here. | Joel Sherrill | 1 | -0/+80 | |
1999-10-20 | Moving things to an rtems subdirectory like the other tools. | Joel Sherrill | 2 | -80/+0 | |
1999-10-20 | New file. | Joel Sherrill | 1 | -0/+177 | |
1999-10-20 | Added RPM release numbers. | Joel Sherrill | 2 | -10/+25 | |
1999-10-20 | Generated files removed. | Joel Sherrill | 11 | -307/+155 | |
1999-10-20 | Obsoleted. | Joel Sherrill | 1 | -34/+0 | |
1999-10-20 | Obsoleted as they were distributed to subdirectories. | Joel Sherrill | 4 | -473/+0 | |
1999-10-20 | Made this more binutils like. :) | Joel Sherrill | 1 | -5/+9 | |
1999-10-20 | New file. | Joel Sherrill | 1 | -0/+104 | |
1999-10-20 | New files. | Joel Sherrill | 2 | -0/+285 | |
1999-10-20 | Adding the infrastructure for gdb. | Joel Sherrill | 10 | -47/+155 | |
1999-10-20 | Corrected typo. | Joel Sherrill | 1 | -3/+3 | |
1999-10-20 | Restored joel's changes after merging old version from Ralf. | Joel Sherrill | 1 | -19/+90 | |
1999-10-20 | New version from Ralf. | Joel Sherrill | 28 | -213/+3357 | |
1999-10-20 | Committing changes before Ralf's changed. | Joel Sherrill | 4 | -24/+92 | |
1999-10-19 | Left to build overnight. | Joel Sherrill | 7 | -10/+123 | |
1999-10-19 | Made it easier to change version numbers. | Joel Sherrill | 2 | -15/+21 | |
1999-10-19 | Now easier to modify version numbers in scripts. | Joel Sherrill | 2 | -14/+20 | |
1999-10-19 | Easier to insert tool version number. | Joel Sherrill | 2 | -20/+31 | |
1999-10-18 | Making sparc-rtems rpms available. | Joel Sherrill | 3 | -2/+3 | |
1999-10-18 | Working on being able to cut RPMs. It now appears that the process | Joel Sherrill | 12 | -27/+788 | |
is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets. | |||||
1999-10-15 | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 7 | -0/+399 | |
help build RPMs. |
