* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* gcc3newlib/base-gcj.add, gcc3newlib/gccnewlib.add,
gcc3newlib/target-gcj.add: First attempt at enabling Java support.
* setup.def, gcc3newlib/gccnewlib.add: Updated the tools for
gcc 3.2 and Ada.
* gcc3newlib/gccnewlib.add: Re-add i386-rtems Ada.
Add %_gnat and --define 'gnat [0|1]' support.
Enable gnat for gcc-3.2/Disable for gcc-3.1.
Add hacks to build gnatlib.
Re-activate commented out fragments for old gcc versions.
Add @target_alias@-gnatgcc.
* setup.def: New gcc 3.1 RPMs (-7).
* gcc3newlib/gccnewlib.add: i386-rtems doesn't build Ada.
* gcc3newlib/Makefile.am: Remove c_only remnants.
* gcc3newlib/gccnewlib.add: Reflect gcc-3.2 putting c++
headers into c++ instead of g++.
* gcc3newlib/target-c++.add: Ditto.
* ChangeLog: Fix bogus entry.
* gcc3newlib/base-gnat.add: Don't use %{%prefix}/bin/gnat*.
* gcc3newlib/Makefile.am: Use mkspec for c4x.
* gcc3newlib/gccnewlib.add: Rework processing of %if %build_XXX.
Rework handing Ada.
Don't put adalib and adainclude into files.gcc.
* gcc3newlib/target-gnat.add: Add adalib.
Add adainclude.
* gcc3newlib/base-gnat.add: Use -n rtems-base-gnat.
* gcc3newlib/.cvsignore: Add mkspec.
* mkgcc3newlibspec.in: Remove
* gcc3newlib/mkspec.in: New.
* gcc3newlib/gccnewlib.add: Add build_XXX defines.
Add preliminary gnat support.
* gcc3newlib/base-g77.add: Add build_g77.
* gcc3newlib/base-gcj.add: Add build_gcj.
* gcc3newlib/base-gnat.add: New.
* gcc3newlib/target-c++.add: Add build_cxx.
* gcc3newlib/target-g77.add: Add build_g77.
* gcc3newlib/target-gcj.add: Add build_gcj.
* gcc3newlib/target-objc.add: Add build_objc.
* gcc3newlib/target-gnat.add: New.
* gcc3newlib/Makefile.am: Use ./mkspec. Use unified spec.
* setup.def: Increment release for gcc3newlib.
* gcc3newlib/gccnewlib.add: Do not put cc1plus into gcc-rpm.
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* setup.def: Updating gcc3/newlib patches and tool versions. The
focus of this round of patches was ot eliminate header file name
conflicts between RTEMS and newlib.
* setup.def: Updated to gcc3.1/newlib 1.10.0 RPM revision 5 with
the gcc3 patch 20020730a and newlib 1.10.0 patch 20020726.
* autotools/automake-rtems.spec.in: Automake-1.6.3.
* cpukit/.cvsignore: Add mkspec. Remove rtems.spec.
* configure.ac: Use AC_CONFIG_FILES(script, chmod +x script)
to generate mk*spec scripts.
* mkbspspec.in: Use ',' as pattern delimiter in sed expression
for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed
expression for $rpm_build_root.
* cpukit/mkspec.in: Cosmetical changes.
* ChangeLog: Fix 2002-07-22 ChangeLog entry bogusly referring to
Joel.
* cpukit/Makefile.am: New.
* cpukit/mkspec.in: New.
* cpukit/rtems-cpukit.spec.in: New.
* cpukit/.cvsignore: New.
* configure.ac: Add cpukit.
Add RTEMS_TOP to pickup _RTEMS_VERSION (required by cpukit).
* Makefile.am: Add cpukit. Add ACLOCAL_AMFLAGS (required to pickup
RTEMS_VERSION).
* setup.def: Use %{_tmppath} as default for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed expression
* mkgccnewlibspec.in: Use ',' as pattern delimiter in sed
* mkgcc3newlibspec.in: Use ',' as pattern delimiter in sed
* mkgdbspec.in: Use ',' as pattern delimiter in sed expression for
$rpm_build_root.
* binutils/Makefile.am: Add or32-rtems-binutils.
* setup.def: Updated newlib patch to get sh and hppa crt0 mods.
* setup.def: Update gcc3 RPMs for new patches.
* autotools/automake-rtems.spec.in: Update to automake-1.6.2.
* mkgdbspec.in, setup.def, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Updated to gcc 3.1 and gdb 5.2.
* setup.def: Updated to binutils 2.12.1.
* rtems/Makefile.am: Remove m68k-rtemself references.
* mkgcc3newlibspec.in: Remove SETUP (bogus).
* gcc3newlib/target-c++.add: New.
* gcc3newlib/Makefile.am: Add target-c++.add.
* gcc3newlib/base-g77.add: Adapt to gcc-3.1.
Reflect having split out c++. Various minor fixes.
* gcc3newlib/base-gcc.add: Ditto.
* gcc3newlib/gccnewlib.add: Ditto.
* gcc3newlib/target-gcc.add: Ditto.
* gcc3newlib/gccnewlib.add: Add gcc_update --touch to fix
timestamps.
* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* autotools/automake-rtems.spec.in: Update to automake-1.6.1.
Use *.tar.bz2.
* mkbinutilspec.in: Fix PATCH2.
* gcc3newlib/gccnewlib.add: Add -Bgcc/ when collecting multilibs.
* gcc3newlib/gccnewlib.spec.in: Removed from CVS.
* mkbinutilspec.in: Add support for empty patch-version (no patch).
* mkgcc3newlibspec.in: Ditto.
* setup: Fix gcc3*_versions handling.
* setup.def: binutils_patch_version=.
* binutils/binutils.add: Reflect changes to mkbinutilspec.in,
Use "%{_target_os}" != "%{_build_os}" to detect cross-building.
* binutils/target-binutils.add: Comment out c++filt.
* gcc3newlib/base-gcc.add: Remove duplicate libm.info.
* gcc3newlib/gccnewlib.add: Reflect changes to mkgcc3newlibspec.in.
Comment out gcc-2.95.x hacks.
Remove *.la from installed files.
* gcc3newlib/gccnewlib_c_only.spec.in: Remove.
* buildall.in: Correct logic for detecting 0 RTEMS RPMS installed.
* .cvsignore: Added mkgcc3newlib.
* gcc3newlib/.cvsignore: New file.
* Per PR64 added support for gcc 3.x RPMs
* Makefile.am, configure.ac, mkspec, setup, setup.def: Modified.
* mkgcc3newlibspec.in: New file.
* gcc3newlib: New subdirectory.
* base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add,
gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am,
README, target-g77.add, target-gcc.add, target-gcj.add,
target-objc.add: New files.
* binutils/binutils.add: Commented out patch since binutils 2.12
does not require one.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR151
* autotools/automake-rtems.spec.in: New.
* autotools/automake-rtems.spec: Removed.
* PR151
* configure.ac: Be a little more lenient in matching sparc-solaris.
* mkbinutilspec.in, mkgccnewlibspec.in, gccnewlib/base-chill.add,
gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/gccnewlib.add,
gccnewlib/target-chill.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-objc.add: Added more support for Canadian Cross
building.
* buildall.in: Corrected logic for detecting when no RPMs are installed.
* README: Added Canadian Cross instructions.
* configure.ac: Add AC_PREFIX_DEFAULT([/opt/rtems]).
* mkbinutilsspec.in: Add propagation of @prefix@.
* binutils/base-binutils.add:
Let %post and %unpost apply %{_prefix}.
Apply %{_prefix} instead of /opt/rtems.
* binutils/binutils.add: Update copyright notice.
Add _prefix.
Remove -a 0 in %setup.
Rework hack to SuSE's rpm screwing up %{_target}.
Replace ARGS with CONFIGURE_ARGS.
* binutils/binutils.add: Add initial support for building
Canadian cross RPMs. It should work like this:
cd rtems/scripts
./configure --build=`../config.guess` --host=i386-cygwin
rpm --target=i386-cygwin \
/usr/src/redhat/SPECS/<target>-binutils-..spec.
alien -t /usr/src/redhat/RPMS/....i386.rpm
.. and voila ... your tarball, with rpm-consistency checks etc. applied.
* buildalltar.in: Modified to support Canadian cross builds.
It was testing using a RedHat 7.2 host to build *-rtems tools
that run on an i386-cygwin host.
* configure.ac: Fix typo to allow custom RPM_SPECSdirs.
* setup.def: Bumped the gdb_patch_version to account for a configuration
problem on psim where it could not be enabled for powerpc-RTEMS.
* gdb/Makefile.am: Add i386-RTEMS and powerpc-RTEMS targets.
