1999-11-02 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
1999-11-02 | Clean up /opt/rtems in case junk is installed in the wrong place. | Joel Sherrill | 1 | -4/+4 | |
This has been seen on some machine configurations. | |||||
1999-10-27 | Latest version from Ralf Corsepius <corsepiu@faw.uni-ulm.de> which | Joel Sherrill | 1 | -44/+103 | |
splits gcc, gcj, chill, f77 and objc into separate rpms.. | |||||
1999-10-26 | Removing automatically generated files. | Joel Sherrill | 4 | -1088/+0 | |
1999-10-26 | Removed generated file. | Joel Sherrill | 1 | -1101/+0 | |
1999-10-26 | New versions for gcc and patch. | Joel Sherrill | 1 | -2/+2 | |
1999-10-26 | Regenerated | Joel Sherrill | 6 | -27/+34 | |
1999-10-25 | Patch generated from scripts-19991025-0.tar.gz from | Joel Sherrill | 10 | -74/+143 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages) | |||||
1999-10-25 | Regnenerated following update from Ralf. | Joel Sherrill | 6 | -27/+34 | |
1999-10-25 | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 10 | -122/+82 | |
1999-10-25 | Changed version number. | Joel Sherrill | 1 | -1/+1 | |
1999-10-21 | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 6 | -9/+59 | |
1999-10-21 | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 14 | -9/+27 | |
not right yet. Now can specify rpm_build_root via setup. | |||||
1999-10-21 | Now can specify rpm_build_root via setup. | Joel Sherrill | 1 | -2/+2 | |
Changed package name so generated RPM would have a nicer name. | |||||
1999-10-21 | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 10 | -143/+176 | |
1999-10-21 | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 19 | -135/+231 | |
issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | |||||
1999-10-21 | Shipping this all to Ralf. | Joel Sherrill | 2 | -6/+7 | |
1999-10-20 | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 7 | -19/+42 | |
functioned. | |||||
1999-10-20 | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 2 | -34/+37 | |
functioned. Merged Ralf's changes into gccnewlib.spec.in. | |||||
1999-10-20 | New file. | Joel Sherrill | 1 | -0/+50 | |
1999-10-20 | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 13 | -199/+35 | |
Ralf's end of day version. | |||||
1999-10-20 | Moved rtems specific files into here. | Joel Sherrill | 1 | -0/+80 | |
1999-10-20 | Moving things to an rtems subdirectory like the other tools. | Joel Sherrill | 2 | -80/+0 | |
1999-10-20 | New file. | Joel Sherrill | 1 | -0/+177 | |
1999-10-20 | Added RPM release numbers. | Joel Sherrill | 2 | -10/+25 | |
1999-10-20 | Generated files removed. | Joel Sherrill | 11 | -307/+155 | |
1999-10-20 | Obsoleted. | Joel Sherrill | 1 | -34/+0 | |
1999-10-20 | Obsoleted as they were distributed to subdirectories. | Joel Sherrill | 4 | -473/+0 | |
1999-10-20 | Made this more binutils like. :) | Joel Sherrill | 1 | -5/+9 | |
1999-10-20 | New file. | Joel Sherrill | 1 | -0/+104 | |
1999-10-20 | New files. | Joel Sherrill | 2 | -0/+285 | |
1999-10-20 | Adding the infrastructure for gdb. | Joel Sherrill | 10 | -47/+155 | |
1999-10-20 | Corrected typo. | Joel Sherrill | 1 | -3/+3 | |
1999-10-20 | Restored joel's changes after merging old version from Ralf. | Joel Sherrill | 1 | -19/+90 | |
1999-10-20 | New version from Ralf. | Joel Sherrill | 28 | -213/+3357 | |
1999-10-20 | Committing changes before Ralf's changed. | Joel Sherrill | 4 | -24/+92 | |
1999-10-19 | Left to build overnight. | Joel Sherrill | 7 | -10/+123 | |
1999-10-19 | Made it easier to change version numbers. | Joel Sherrill | 2 | -15/+21 | |
1999-10-19 | Now easier to modify version numbers in scripts. | Joel Sherrill | 2 | -14/+20 | |
1999-10-19 | Easier to insert tool version number. | Joel Sherrill | 2 | -20/+31 | |
1999-10-18 | Making sparc-rtems rpms available. | Joel Sherrill | 3 | -2/+3 | |
1999-10-18 | Working on being able to cut RPMs. It now appears that the process | Joel Sherrill | 12 | -27/+788 | |
is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets. | |||||
1999-10-15 | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 7 | -0/+399 | |
help build RPMs. |
