* scripts/automake.spec.in: 1.8.1.
Add Patch0 automake-1.8.1-rtems-20040112-1.diff.
Add defattr, URL:-tag.
* setup.def: Update gcc/newlib for 4.7 series to 3.3.2 with 20031216
gcc patch (RPM revision 4.7-2).
* buildall.in, buildalltar.in, binutils/Makefile.am,
cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am,
gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore,
rtemsdoc/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* setup.def: Update gcc/newlib for 4.7 series to 3.3.2 with 20031022
gcc patch (RPM revision 4.7-1).
* Makefile.am: Cosmetics.
* autotools/Makefile.am: Cosmetics.
* autotools/autoconf-rtems.spec.in: 2.59.
* autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59.
* binutils/Makefile.am: Cosmetics.
* cpukit/Makefile.am: Cosmetics.
* gcc3newlib/Makefile.am: Cosmetics.
* gccnewlib/Makefile.am: Cosmetics.
* gdb/Makefile.am: Cosmetics.
* rtems/Makefile.am: Cosmetics.
* rtemsdoc/Makefile.am: Cosmetics.
* gcc3newlib/gccnewlib.add: Add hacks to make gnatlib
buildable.
* gcc3newlib/base-gnat.add: Add info files.
* gcc3newlib/gccnewlib.add: Make not building gnat and gcj the
default for gcc-3.3.
* binutils/Makefile.am: Add tic4x.
* binutils/mkspec.in: Remove duplicate rpmgroup.
* gcc3newlib/Makefile.am: Add tic4x.
* gcc3newlib/gccnewlib.add: Don't install install-tools for
gcc >= 3.3.
* configure.ac, setup.def: Update to binutils 2.14 adn gcc/newlib to
3.2.3 with 20030826 gcc patch.
* cpukit/target-cpukit.add: New.
* cpukit/Makefile.am: Reflect having added target-cpukit.add.
Acknowledge osversion.
* cpukit/mkspec.in: Acknowledge osversion and rpmgroup.
* cpukit/rtems-cpukit.add: Reflect new RTEMS spec conventions.
* autotools/automake-rtems.spec.in: Automake-1.7.8.
rtemsdoc/Makefile.am: Obsoleting HP PA-RISC port.
* autotools/automake-rtems.spec.in: Automake-1.7.7.
* gcc3newlib/gccnewlib.add: Fix duplicate removal of c++filt.
* gcc3newlib/base-gcj.add: Add fastjar.info, jar.1, grepjar.1.
* setup.def: gcc3newlib_rpm_release=4.
* binutils/base-binutils.add: Add osversion support.
* binutils/binutils.add: Add osversion support.
%setup -n %{name}-%{version}.
Don't remove c++filt.
* binutils/target-binutils.add: Add osversion support.
Pickup c++filt.
* gcc3newlib/base-g77.add: Add osversion support.
* gcc3newlib/base-gcc.add: Add osversion support.
* gcc3newlib/base-gcj.add: Add osversion support.
* gcc3newlib/base-gnat.add: Add osversion support.
* gcc3newlib/gccnewlib.add: Add osversion support.
Remove c++filt,
%setup -n -n %{name}-%{version}.
* gcc3newlib/target-c++.add: Add osversion support.
Don't pickup c++filt.
* gcc3newlib/target-g77.add: Add osversion support.
* gcc3newlib/target-gcc.add: Add osversion support.
* gcc3newlib/target-gcj.add: Add osversion support.
* gcc3newlib/target-gnat.add: Add osversion support.
* gccnewlib/gccnewlib.add: %setup -n %{name}-%{version}.
* gdb/base-gdb.add: Add osversion support, rpmgroup, rpmprefix,
gdb_version, gdb_target.
* gdb/target-gdb.add: Ditto.
* gdb/gdb.add: Ditto.
* binutils/Makefile.am: Fix osversion support for sh-rtemself.
* gcc3newlib/Makefile.am: Fix osversion support for sh-rtemself.
* configure.ac: Add --enable-osversions (OS-versioned RPMS support).
* binutils/Makefile.am: Add osversion support.
* binutils/mkspec.in: Add osversion support.
* gcc3newlib/Makefile.am: Add osversion support.
* gcc3newlib/mkspec.in: Add osversion support.
* gdb/Makefile.am: Add osversion support.
* gdb/mkspec.in: Add osversion support.
Add rpmprefix, rpmgroup.
* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
binutils/target-binutils.add,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gdb/Makefile.am,
rtems/Makefile.am,
Merger from rtems-4-6-branch.
* common/common.am: New.
* common/common.add.in: s/www.oarcorp.com/www.rtems.com/.
Add %define __os_install_post %{nil} to prevent RH-9's rpm-brp-strip
from running (Chokes on foreign object formats).
Use %{gcc_version} instead of @gcc_version@.
Reflect gcc >= 3.3 shipping monolytic infos.
* gcc3newlib/target-objc.add:
* binutils/binutils.add: Preps for 2.14.
Use %{binutils_version} instead of @binutils_version@.
* binutils/base_binutils.add: Preps for 2.14.
* autotools/automake-rtems.spec.in: Automake-1.7.6.
* autotools/automake-rtems.spec.in: Automake-1.7.5.
* setup.def: Updated for RPM revision 3 of gcc3.2.3 and newlib1.11.0.
* setup.def: Update to gcc3.2.3newlib1.11.0-1.
* gcc3newlib/gccnewlib.add: We used .bz2 files.
* setup.def: Update to gcc3.2.2newlib1.11.0-2.
* setup.def: Updated gdb revision to -2 so arm will build and
to fix psim build problem on NetBSD.
* gcc3newlib/gccnewlib.add: Ignore dependency on GNAT RPM since
RedHat 7.3 doesn't have it available. Maybe later.
* gdb/Makefile.am: Cleanup way the RPM_SPECS_DATA variable is built.
* gdb/gdb.add, gdb/mkspec.in, gdb/target-gdb.add: Use RPM logic to
determine which targets have simulators, configure with appropriate
arguments, and package the correct files.
* gcc3newlib/target-gcc.add: Remove %{_exeext} from gccbug.
* gcc3newlib/gccnewlib.add: Add %gcj to support to disabling building
gcj from rpmbuild command line.
Copy gsyslimits.h for CDN-X compilation.
* Apply the 2003-01-31 changes OAR's broken CVS had dropped.
* README.cdn-X: New.
* binutils/binutils.add: Add --build=%_build --host=%_host.
* cpukit/.cvsignore: Add *.spec.in.
* gcc3newlib/gccnewlib.add: Add --build=%_build --host=%_host.
* gdb/gdb.add: Add --build=%_build --host=%_host.
* rtemsdoc/.cvsignore: Add *.spec.in.
* gcc3newlib/gccnewlib.add: Remove Buildroot.
* common/.cvsignore: New.
* common/common.add.in: Add Vendor, Distribution, BuildRoot.
* binutils/Makefile.am: Fix path to clean.add.
* binutils/binutils.add: Remove BuildRoot.
* cpukit/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtems-cpukit.spec.in.
* cpukit/header.add: New.
* cpukit/rtems-cpukit.spec.in: Remove.
* cpukit/rtems-cpukit.add: New.
* gccnewlib/gccnewlib.add: Remove Buildroot.
* gdb/gdb.add: Remove Buildroot.
* rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add,
Generate rtemsdoc.spec.in.
* rtemsdoc/mkspec.in: Remove exe_ext.
* rtemsdoc/rtemsdoc.spec.in: Remove.
* gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add,
* gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}.
Remove header, broken cdn-X configuration, %clean.
* gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* gdb/gdb.add: Remove header, broken cdn-X configuration,
%clean, Replace @exe_ext@ with %{_exeext}.
* gdb/mkspec.in: Remove exe_ext.
* gdb/target-gdb.add: Replace @exe_ext@ with %{_exeext}.
* gdb/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* cpukit/mkspec.in: Remove exe_ext.
* binutils/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/gccnewlib.add: Remove header, broken cdn-X configuration,
* gcc3newlib/mkspec.in: Remove exe_ext.
* gcc3newlib/target-c++.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gnat.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
+ gcc3newlib/Makefile.am: Use $(top_builddir)/common/common.add,
* Makefile.am: Remove reference to mkbinutilsspec.
* configure.ac: Remove EXEEXT check.
Add common/clean.add, common/common.add.
* binutils/binutils.add: Remove header, broken cdn-X configuration,
%clean.
* binutils/mkspec.in: Remove exe_ext, build_alias, host_alias.
* binutils/target-binutils.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/header.add: New.
* gccnewlib/header.add: New.
* binutils/header.add: New.
* gdb/header.add: New.
* rtemsdoc/header.add: New.
* rtemsdoc/rtemsdoc.add: New.
* common/clean.add.in: New.
* common/common.add.in: New.
* binutils/Makefile.am: Reflect changes above.
* binutils/mkspec.in: New.
* binutils/.cvsignore: Add mkspec.
* mkbinutilspec.in: Remove.
* gdb/Makefile.am: Depend on mkspec.
* binutils/binutils.add: Add @exe_ext@ to c++filt.
Add %_defaultbuildroot.
* gdb/.cvsignore: Add mkspec.
* ChangeLog: Fix yesterday's entry.
* gdb/target-gdb.add: %defattr(-,root,root).
Use %{_prefix} instead of /opt/rtems.
Misc. minor changes.
* gdb/gdb.add: Use %{_prefix} instead of /opt/rtems.
Remove stray unpackaged files.
Use %{_defaultbuildroot} instead of hard-coded values.
configure --disable-nls.
Add BuildPreReq: ncurses-devel.
* gdb/base-gdb.add: %defattr(-,root,root).
* gdb/mkspec.in: New.
* gdb/Makefile.am: Reflect addition of gdb/mkspec.in.
* gcc3newlib/mkspec.in: Fix usage.
* gcc3newlib/gccnewlib.add: Use %{_defaultbuildroot} instead of
hard-coded values. Update copyright notice.
* mkgdbspec.in: Removed.
* Makefile.am: Remove mkgdbspec.
* configure.ac: Remove mkgdbspec.
Add gdb/mkspec.
* gccnewlib.add: Add various BuildPreReq.
Add %defattr(-,root,root) to "dir".
* base-g77.add: %defattr(-,root,root).
* base-gcc.add %defattr(-,root,root).
* base-gcj.add %defattr(-,root,root).
* base-gnat.add %defattr(-,root,root).
* target-c++.add %defattr(-,root,root).
* target-g77.add %defattr(-,root,root).
* target-gcc.add %defattr(-,root,root).
* target-gcj.add %defattr(-,root,root).
* target-gnat.add %defattr(-,root,root).
* target-objc.add %defattr(-,root,root).
* ChangeLog: binutils/binutils.add-entry from previous patch.
