* autotools/autoconf-rtems.spec.in: Comment out line giving trouble. It
only references unneeded documentation.
PR 594/tools
* setup.def, autotools/autoconf-rtems.spec.in: Increment and rebuild so
GNAT included.
* autotools/autoconf-rtems.spec.in: Remove bogus BuildDep on
autoconf.
* autotools/automake-rtems.spec.in: Use my rtems.org address.
* autotools/autoconf-rtems.spec.in: Backport from rtems-4.7.
Update to autoconf-2.59.
PR 594/tools
GNAT included.
* Makefile.am: Use rtems_source_spec_DEPS instead of
rtems_source_spec_DEPENDENCIES (Conflicts with automake internals).
* configure.ac: Remove rtemsdoc/mkspec.
* rtemsdoc/.cvsignore: Reformat.
* configure.ac: Add RTEMS_RPM_RELEASE.
* Makefile.am: Reformat. Add RTEMS_RPM_RELEASE support to
rtems-source.add
* rtems/rtems-source.add: Add RTEMS_RPM_RELEASE.
* rtemsdoc/mkspec.in: Remove.
* rtemsdoc/Makefile.am: Reworked.
* rtemsdoc/header.add: Update Copyright notice.
* rtemsdoc/rtemsdoc.add: Add RTEMS_RPM_RELEASE.
Add %{rpmgroup}. Remove bzip-ing *.ps.
* rtemsdoc/supplement.add.in: Add %{rpmgroup}.
* rtemsdoc/templ.add.in: Add %{rpmgroup}.
* rtems/rtems-source.add: New.
* Makefile.am: Add rtems/rtems-source.spec handling.
* configure.ac: AC_SUBST(RTEMS_VERSION,[_RTEMS_VERSION]).
* common/common.add.in: Use www.rtems.com as Vendor.
Cherrypick from master 2004-02-01 08:27:24 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>':
aclocal/rpm.m4
Cherrypick from master 2004-02-09 13:21:24 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>':
scripts/rtems/rtems-source.add
* setup.def: Reflect new binutils RPM revision to correct defattr.
* configure.ac: Use all CAPS RTEMS.
* setup.def: Make it match gcc 3.2.3 RPMs.
* scripts/automake.spec.in: Add defattr, URL:-tag.
Release 2.
* binutils/base-binutils.add: Add osversion support.
* binutils/binutils.add: Add osversion support.
%setup -n %{name}-%{version}.
Don't remove c++filt.
* binutils/target-binutils.add: Add osversion support.
Pickup c++filt.
* gcc3newlib/base-g77.add: Add osversion support.
* gcc3newlib/base-gcc.add: Add osversion support.
* gcc3newlib/base-gcj.add: Add osversion support.
* gcc3newlib/base-gnat.add: Add osversion support.
* gcc3newlib/gccnewlib.add: Add osversion support.
Remove c++filt,
%setup -n -n %{name}-%{version}.
* gcc3newlib/target-c++.add: Add osversion support.
Don't pickup c++filt.
* gcc3newlib/target-g77.add: Add osversion support.
* gcc3newlib/target-gcc.add: Add osversion support.
* gcc3newlib/target-gcj.add: Add osversion support.
* gcc3newlib/target-gnat.add: Add osversion support.
* gccnewlib/gccnewlib.add: %setup -n %{name}-%{version}.
* gdb/base-gdb.add: Add osversion support, rpmgroup, rpmprefix,
gdb_version, gdb_target.
* gdb/target-gdb.add: Ditto.
* gdb/gdb.add: Ditto.
2003-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* binutils/Makefile.am: Fix osversion support for sh-rtemself.
* gcc3newlib/Makefile.am: Fix osversion support for sh-rtemself.
* configure.ac: Add --enable-osversions (OS-versioned RPMS support).
* binutils/Makefile.am: Add osversion support.
* binutils/mkspec.in: Add osversion support.
* gcc3newlib/Makefile.am: Add osversion support.
* gcc3newlib/mkspec.in: Add osversion support.
* gdb/Makefile.am: Add osversion support.
* gdb/mkspec.in: Add osversion support.
Add rpmprefix, rpmgroup.
* binutils/base-binutils.add: Preps for 2.14 (Merger from CVS trunk).
* binutils/binutils.add: Use %{binutils_version} instead of
@binutils_version@ (Missed in previous patches).
* autotools/autoconf.spec.in, autotools/automake.spec.in:
Add rpmgroup, rpmprefix support.
* binutils/mkspec.in: Use ',' as sed-delimiter for %{rpmprefix}.
* common/common.add.in: Add _infodir, _mandir, rpmprefix, rpmgroup.
* configure.ac: Add --enable-pkgprefix, rpmgroup.
* base-g77.add, base-gcc.add, base-gcj.add, base-gnat.add,
target-c++.add, target-g77.add, target-gcc.add, target-gcj.add,
target-gnat.add, target-objc.add
Add support for %{rpmprefix}, %{rpmgroup}.
Use %{gcc_target and %{gcc_version}.
Remove "Provides:".
* gccnewlib.add: Ditto.
Correct setting up _gcj.
Explicitly build c++filt for gcc >= 3.3.
* mkspec.in: Add support for %{rpmprefix}, %{rpmgroup}.
* binutils/Makefile.am: Minor cleanups.
* binutils/binutils.add, binutils/base-binutils.add,
binutils/target-binutils.add: Add support for %{rpmprefix},
%{rpmgroup}. Use %{binutils_target} and %{binutils_version}.
* binutils/mkspec.in:: Add support for @rpmprefix@, @rpmgroup@.
* common/commom.am: New.
* Makefile.am: Remove TEMPLATES.
Put setup.cache into CONFIG_STATUS_DEPENDENCIES instead of
CONFIGURE_DEPENDENCIES.
* configure.ac: Remove AC_PREFIX_DEFAULT.
* binutils/Makefile.am: include common.am.
* common/common.add.in: Use rtems.com gnats.
* cpukit/Makefile.am: include common.am.
* gcc3newlib/Makefile.am: include common.am.
* gccnewlib/Makefile.am: include common.am.
* gdb/Makefile.am: include common.am.
* rtems/Makefile.am: include common.am.
* rtemsdoc/Makefile.am: include common.am.
* setup.def: Recovery effort.
* setup.def: Updated for RPM revision 3 of gcc3.2.3 and newlib1.11.0.
* common/common.add.in: Add %define __os_install_post %{nil} to
work around rpm-4.2 choking on foreign file types.
* ChangeLog, gcc3newlib/gccnewlib.add, gdb/Makefile.am: Merged from
head.
* gcc3newlib/gccnewlib.add: Add %gcc_version, %newlib_version.
Apply %gcc_version, %newlib_version.
* gcc3newlib/target-c++.add: Apply %gcc_version, %newlib_version.
* gcc3newlib/target-g77.add: Apply %gcc_version, %newlib_version.
* gcc3newlib/target-gcc.add: Apply %gcc_version, %newlib_version.
* gcc3newlib/target-gcj.add: Apply %gcc_version, %newlib_version.
* gcc3newlib/target-gnat.add: Apply %gcc_version, %newlib_version.
* gcc3newlib/target-objc.add: Apply %gcc_version, %newlib_version.
* gdb/gdb.add, gdb/mkspec.in, gdb/target-gdb.add: Use RPM logic to
determine which targets have simulators, configure with appropriate
arguments, and package the correct files.
* gcc3newlib/target-gcc.add: Remove %{_exeext} from gccbug.
* gcc3newlib/gccnewlib.add: Add %gcj to support to disabling building
gcj from rpmbuild command line.
Copy gsyslimits.h for CDN-X compilation.
* Apply the 2003-01-31 changes OAR's broken CVS had dropped.
* README.cdn-X: New.
* binutils/binutils.add: Add --build=%_build --host=%_host.
* cpukit/.cvsignore: Add *.spec.in.
* gcc3newlib/gccnewlib.add: Add --build=%_build --host=%_host.
* gdb/gdb.add: Add --build=%_build --host=%_host.
* rtemsdoc/.cvsignore: Add *.spec.in.
* gcc3newlib/gccnewlib.add: Remove Buildroot.
* common/.cvsignore: New.
* common/common.add.in: Add Vendor, Distribution, BuildRoot.
* binutils/Makefile.am: Fix path to clean.add.
* binutils/binutils.add: Remove BuildRoot.
* cpukit/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtems-cpukit.spec.in.
* cpukit/header.add: New.
* cpukit/rtems-cpukit.spec.in: Remove.
* cpukit/rtems-cpukit.add: New.
* gccnewlib/gccnewlib.add: Remove Buildroot.
* gdb/gdb.add: Remove Buildroot.
* rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add,
Generate rtemsdoc.spec.in.
* rtemsdoc/mkspec.in: Remove exe_ext.
* rtemsdoc/rtemsdoc.spec.in: Remove.
* gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add,
* gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}.
Remove header, broken cdn-X configuration, %clean.
* gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* gdb/gdb.add: Remove header, broken cdn-X configuration,
%clean, Replace @exe_ext@ with %{_exeext}.
* gdb/mkspec.in: Remove exe_ext.
* gdb/target-gdb.add: Replace @exe_ext@ with %{_exeext}.
* gdb/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* cpukit/mkspec.in: Remove exe_ext.
* binutils/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/gccnewlib.add: Remove header, broken cdn-X configuration,
* gcc3newlib/mkspec.in: Remove exe_ext.
* gcc3newlib/target-c++.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gnat.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
+ gcc3newlib/Makefile.am: Use $(top_builddir)/common/common.add,
* Makefile.am: Remove reference to mkbinutilsspec.
* configure.ac: Remove EXEEXT check.
Add common/clean.add, common/common.add.
* binutils/binutils.add: Remove header, broken cdn-X configuration,
%clean.
* binutils/mkspec.in: Remove exe_ext, build_alias, host_alias.
* binutils/target-binutils.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/header.add: New.
* gccnewlib/header.add: New.
* binutils/header.add: New.
* gdb/header.add: New.
* rtemsdoc/header.add: New.
* rtemsdoc/rtemsdoc.add: New.
* common/clean.add.in: New.
* common/common.add.in: New.
* binutils/Makefile.am: Reflect changes above.
* binutils/mkspec.in: New.
* binutils/.cvsignore: Add mkspec.
* mkbinutilspec.in: Remove.
* gdb/Makefile.am: Depend on mkspec.
* binutils/binutils.add: Add @exe_ext@ to c++filt.
Add %_defaultbuildroot.
* gdb/.cvsignore: Add mkspec.
* ChangeLog: Fix yesterday's entry.
* gdb/target-gdb.add: %defattr(-,root,root).
Use %{_prefix} instead of /opt/rtems.
Misc. minor changes.
* gdb/gdb.add: Use %{_prefix} instead of /opt/rtems.
Remove stray unpackaged files.
Use %{_defaultbuildroot} instead of hard-coded values.
configure --disable-nls.
Add BuildPreReq: ncurses-devel.
* gdb/base-gdb.add: %defattr(-,root,root).
* gdb/mkspec.in: New.
* gdb/Makefile.am: Reflect addition of gdb/mkspec.in.
* gcc3newlib/mkspec.in: Fix usage.
* gcc3newlib/gccnewlib.add: Use %{_defaultbuildroot} instead of
hard-coded values. Update copyright notice.
* mkgdbspec.in: Removed.
* Makefile.am: Remove mkgdbspec.
* configure.ac: Remove mkgdbspec.
Add gdb/mkspec.
* gccnewlib.add: Add various BuildPreReq.
Add %defattr(-,root,root) to "dir".
* base-g77.add: %defattr(-,root,root).
* base-gcc.add %defattr(-,root,root).
* base-gcj.add %defattr(-,root,root).
* base-gnat.add %defattr(-,root,root).
* target-c++.add %defattr(-,root,root).
* target-g77.add %defattr(-,root,root).
* target-gcc.add %defattr(-,root,root).
* target-gcj.add %defattr(-,root,root).
* target-gnat.add %defattr(-,root,root).
* target-objc.add %defattr(-,root,root).
* ChangeLog: binutils/binutils.add-entry from previous patch.
