* | 2001-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-03-28 | 1 | -0/+20 |
| | | | | | | | | | | | * Per PR64 added support for gcc 3.x RPMs * Makefile.am, configure.ac, mkspec, setup, setup.def: Modified. * mkgcc3newlibspec.in: New file. * gcc3newlib: New subdirectory. * base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add, gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am, README, target-g77.add, target-gcc.add, target-gcj.add, target-objc.add: New files. | ||||
* | RTEMS RPM basically working. | Joel Sherrill | 1999-11-22 | 1 | -4/+12 |
* | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1999-10-21 | 1 | -2/+6 |
| | | | | | | not right yet. Now can specify rpm_build_root via setup. | ||||
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 1 | -2/+7 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Added RPM release numbers. | Joel Sherrill | 1999-10-20 | 1 | -9/+21 |
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 1 | -0/+83 |
