* setup.def: Update rtems_version. Remove rpm_build_root.
* setup.def, gdb/gdb.add: Add gdb_suffix.
* setup, setup.def, gcc3newlib/mkspec.in:
s/gcc3newlib_rpm_release/gccnewlib_rpm_release/g.
* gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, setup.def:
Add gcc_suffix. Add newlib_suffix.
* setup.def: Include PowerPC patch to make C++ global constructors work
-- gcc 3.3.5/newlib-1.12.0 revision 2.
* setup.def: Update gcc to 3.3.5 and binutils to 2.15.
* autotools/autoconf-rtems.spec.in: Temporarily do not include
some of the documentation since it causes the RPM build to fail.
* binutils/Makefile.am, gcc3newlib/Makefile.am: Add mips64-rtems.
PR 580/tools
* setup.def: Fix setup.def to match current reality.
* setup.def, gdb/gdb.add: gdb 6.0 RPMs built.
* setup.def, gdb/base-gdb.add, gdb/gdb.add: Building a gcc 3.2.3 i960
gcc and updating gdb to 5.3.
* configure.ac, setup, setup.def: Remove now unused vars.
* setup.def: Adapt to what Joel already ships -
gcc3_version=3.3.2, gcc3_patch_version=20031216,
gcc3newlib_rpm_release=3
* configure.ac: Enable OS versioning by default for 4.7 branch.
* setup.def: Update binutils RPM version and build new gcc 3.2.3 RPMs.
* autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in:
Update for new tool spin.
* setup.def: Update gcc/newlib for 4.7 series to 3.3.2 with 20031216
gcc patch (RPM revision 4.7-2).
* setup.def: Update gcc/newlib for 4.7 series to 3.3.2 with 20031022
gcc patch (RPM revision 4.7-1).
* configure.ac, setup.def: Update to binutils 2.14 adn gcc/newlib to
3.2.3 with 20030826 gcc patch.
* gcc3newlib/gccnewlib.add: Fix duplicate removal of c++filt.
* gcc3newlib/base-gcj.add: Add fastjar.info, jar.1, grepjar.1.
* setup.def: gcc3newlib_rpm_release=4.
* setup.def: Updated for RPM revision 3 of gcc3.2.3 and newlib1.11.0.
* setup.def: Update to gcc3.2.3newlib1.11.0-1.
* gcc3newlib/gccnewlib.add: We used .bz2 files.
* setup.def: Update to gcc3.2.2newlib1.11.0-2.
* setup.def: Updated gdb revision to -2 so arm will build and
to fix psim build problem on NetBSD.
* gcc3newlib/gccnewlib.add: Ignore dependency on GNAT RPM since
RedHat 7.3 doesn't have it available. Maybe later.
* gdb/Makefile.am: Cleanup way the RPM_SPECS_DATA variable is built.
* setup.def: binutils_rpm_release=2.
* binutils/base-binutils.add: %defattr(-,root,root).
* binutils/binutils.add: Ditto.
* binutils/target-binutils.add: Ditto.
* buildalltar.in, setup.def: Tool update including binaries for Cygwin
with a special RTEMS user account.
* setup.def: Updated gcc 3.2.1newlib1.10.0 RPM to revision 4
to include m68k crti.o/crtn.o multilib patch.
* setup.def: Updated patch to fix m68k cut and paste bug which turned
a tab into spaces in a Makefile fragment.
* gcc3newlib/gccnewlib.add: If building gnat for the mips, the library
must be built with a -G0 option.
* setup.def, gcc3newlib/gccnewlib.add: Updated to gcc 3.2.1 RPM revision
2 which enabled the mips-rtems gnat using gcc 3.2.1 patch 20021129.
* setup.def: Updated to gcc-3.2.1.
* setup.def: Updated to gcc-3.2 and newlib1.1.0 RPM version 6.
* gcc3newlib/gccnewlib.add: Reenabled i386-rtems gnat.
* setup.def: Switched to binutils 2.13.1
* binutils/Makefile.am: Remove a29k-rtems.
* setup.def, gcc3newlib/gccnewlib.add: Patch includes updates
which were patch changes for -3 and -4 RPM revisions. Disabled
build of gnat for i386-rtems as it failed to build.
* setup.def: Update gcc 3.2 pathc to includ epatch for gcc PR8314.
* gcc3newlib/gccnewlib.add: Don't build mips/gnat as we do not
currently include the patch referenced in PR8344.
* setup.def, gcc3newlib/gccnewlib.add: Updated the tools for
gcc 3.2 and Ada.
* setup.def: New gcc 3.1 RPMs (-7).
* gcc3newlib/gccnewlib.add: i386-rtems doesn't build Ada.
* setup.def: Increment release for gcc3newlib.
* gcc3newlib/gccnewlib.add: Do not put cc1plus into gcc-rpm.
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* setup.def: Updating gcc3/newlib patches and tool versions. The
focus of this round of patches was ot eliminate header file name
conflicts between RTEMS and newlib.
* setup.def: Updated to gcc3.1/newlib 1.10.0 RPM revision 5 with
the gcc3 patch 20020730a and newlib 1.10.0 patch 20020726.
* ChangeLog: Fix 2002-07-22 ChangeLog entry bogusly referring to
Joel.
* cpukit/Makefile.am: New.
* cpukit/mkspec.in: New.
* cpukit/rtems-cpukit.spec.in: New.
* cpukit/.cvsignore: New.
* configure.ac: Add cpukit.
Add RTEMS_TOP to pickup _RTEMS_VERSION (required by cpukit).
* Makefile.am: Add cpukit. Add ACLOCAL_AMFLAGS (required to pickup
RTEMS_VERSION).
* setup.def: Use %{_tmppath} as default for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed expression
* mkgccnewlibspec.in: Use ',' as pattern delimiter in sed
expression for $rpm_build_root.
* mkgcc3newlibspec.in: Use ',' as pattern delimiter in sed
* mkgdbspec.in: Use ',' as pattern delimiter in sed expression for
$rpm_build_root.
* setup.def: Updated newlib patch to get sh and hppa crt0 mods.
* setup.def: Update gcc3 RPMs for new patches.
* mkgdbspec.in, setup.def, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Updated to gcc 3.1 and gdb 5.2.
* setup.def: Updated to binutils 2.12.1.
* rtems/Makefile.am: Remove m68k-rtemself references.
* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* mkbinutilspec.in: Add support for empty patch-version (no patch).
* mkgcc3newlibspec.in: Ditto.
* setup: Fix gcc3*_versions handling.
* setup.def: binutils_patch_version=.
* binutils/binutils.add: Reflect changes to mkbinutilspec.in,
Use "%{_target_os}" != "%{_build_os}" to detect cross-building.
* binutils/target-binutils.add: Comment out c++filt.
* gcc3newlib/base-gcc.add: Remove duplicate libm.info.
* gcc3newlib/gccnewlib.add: Reflect changes to mkgcc3newlibspec.in.
Comment out gcc-2.95.x hacks.
Remove *.la from installed files.
* gcc3newlib/gccnewlib_c_only.spec.in: Remove.
* gcc3newlib/.cvsignore: New file.
* Per PR64 added support for gcc 3.x RPMs
* Makefile.am, configure.ac, mkspec, setup, setup.def: Modified.
* mkgcc3newlibspec.in: New file.
* gcc3newlib: New subdirectory.
* base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add,
gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am,
README, target-g77.add, target-gcc.add, target-gcj.add,
target-objc.add: New files.
* PR151
* autotools/automake-rtems.spec.in: New.
* autotools/automake-rtems.spec: Removed.
* setup.def: Bumped the gdb_patch_version to account for a configuration
problem on psim where it could not be enabled for powerpc-RTEMS.
* gdb/Makefile.am: Add i386-RTEMS and powerpc-RTEMS targets.
