* | Updated to new patch. | Joel Sherrill | 2000-07-11 | 1 | -1/+1 |
* | Switch to gcc patch 20000629 and revision level 8. This patch | Joel Sherrill | 2000-06-29 | 1 | -2/+2 |
| | | | | | | fixes: + the h8300-rtems and hppa1.1-rtems configure.in stanzas + config/rs6000/rtems.h start and end file specs | ||||
* | Added initial h8300 support. | Joel Sherrill | 2000-06-29 | 1 | -5/+5 |
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -6/+6 |
* | Updated version numbers. | Joel Sherrill | 2000-02-08 | 1 | -2/+2 |
* | Patches rtems-rc-20000118-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-02-01 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | that contains: * The fix for the gen68360/network/Makefile.am * automatically set permissions to 755 to scripts/buildall and scripts-ada/buildall (I remembered a trick to achieve this :). * automake support for libbsp/* and libcpu/* (Attn: This part will finally break old-style configuration for all non-public cpus) NOTES: * This patch has only been tested for a random selection of BSPs (I haven't rebuilt all toolchains yet). * This patch is against rtem-cvs as of this morning (MET). To apply: patch -p1 <rtems-rc-20000118-5.diff cvs rm -f ./c/src/lib/libbsp/Makefile.in cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in cvs rm -f ./c/src/lib/libcpu/Makefile.in cvs add ./c/src/lib/libbsp/Makefile.am cvs add ./c/src/lib/libbsp/shmdr/Makefile.am cvs add ./c/src/lib/libcpu/Makefile.am ./bootstrap | ||||
* | Changed versions of newlib patch. | Joel Sherrill | 2000-01-31 | 1 | -2/+2 |
* | Updated versions. | Joel Sherrill | 2000-01-31 | 1 | -2/+2 |
* | Removed gnat and made final cleanup. | Joel Sherrill | 2000-01-27 | 1 | -2/+2 |
* | Updated versions. | Joel Sherrill | 2000-01-14 | 1 | -6/+6 |
* | RTEMS RPM basically working. | Joel Sherrill | 1999-11-22 | 1 | -0/+2 |
* | New versions for gcc and patch. | Joel Sherrill | 1999-10-26 | 1 | -2/+2 |
* | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1999-10-21 | 1 | -0/+1 |
* | Added RPM release numbers. | Joel Sherrill | 1999-10-20 | 1 | -1/+4 |
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 1 | -0/+9 |
