* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
binutils/target-binutils.add,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gccnewlib/Makefile.am,
gdb/Makefile.am,
rtems/Makefile.am,
rtemsdoc/Makefile.am:
Merger from rtems-4-6-branch.
* common/common.am: New.
* Apply the 2003-01-31 changes OAR's broken CVS had dropped.
* common/common.add.in: Add Vendor, Distribution, BuildRoot.
* binutils/Makefile.am: Fix path to clean.add.
* binutils/binutils.add: Remove BuildRoot.
* cpukit/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtems-cpukit.spec.in.
* cpukit/header.add: New.
* cpukit/rtems-cpukit.spec.in: Remove.
* cpukit/rtems-cpukit.add: New.
* gccnewlib/gccnewlib.add: Remove Buildroot.
* gdb/gdb.add: Remove Buildroot.
* rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add,
Generate rtemsdoc.spec.in.
* rtemsdoc/mkspec.in: Remove exe_ext.
* rtemsdoc/rtemsdoc.spec.in: Remove.
* gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add,
* gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}.
Remove header, broken cdn-X configuration, %clean.
* gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/header.add: New.
* gccnewlib/header.add: New.
* binutils/header.add: New.
* gdb/header.add: New.
* rtemsdoc/header.add: New.
* rtemsdoc/rtemsdoc.add: New.
* common/clean.add.in: New.
* common/common.add.in: New.
* configure.ac: Add rtemsdoc.
* Makefile.ac: Add rtemsdoc.
* rtemsdoc/README: New.
* rtemsdoc/.cvsignore: New.
* rtemsdoc/Makefile.am: New.
* rtemsdoc/mkspec.in: New.
* rtemsdoc/rtemsdoc.spec.in: New.
* rtemsdoc/supplement.add.in: New.
* rtemsdoc/templ.add.in: New.
