path: root/scripts/rtemsdoc (follow)
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-2/+1
| | | | | | | | * buildall.in, buildalltar.in, binutils/Makefile.am, cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore, rtemsdoc/Makefile.am: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-22/+11
| | | | | | | | | | | | | | * Makefile.am: Cosmetics. * autotools/Makefile.am: Cosmetics. * autotools/autoconf-rtems.spec.in: 2.59. * autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59. * binutils/Makefile.am: Cosmetics. * cpukit/Makefile.am: Cosmetics. * gcc3newlib/Makefile.am: Cosmetics. * gccnewlib/Makefile.am: Cosmetics. * gdb/Makefile.am: Cosmetics. * rtems/Makefile.am: Cosmetics. * rtemsdoc/Makefile.am: Cosmetics.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-262-2/+0
| | | | | | | * buildall.in, buildalltar.in, binutils/Makefile.am, cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore, rtemsdoc/Makefile.am: Obsoleting HP PA-RISC port.
* 2003-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-021-0/+2
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in, binutils/Makefile.am, binutils/base-binutils.add, binutils/binutils.add, binutils/mkspec.in, binutils/target-binutils.add, common/common.add.in, cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/base-g77.add, gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add, gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, gcc3newlib/target-c++.add, gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add, gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add, gcc3newlib/target-objc.add, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/Makefile.am: Merger from rtems-4-6-branch. * common/common.am: New.
* 2003-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-051-0/+1
| | | | * Apply the 2003-01-31 changes OAR's broken CVS had dropped.
* 2003-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-311-1/+0
| | | | | | | | | | | | | | | * common/common.add.in: Add Vendor, Distribution, BuildRoot. * binutils/Makefile.am: Fix path to clean.add. * binutils/binutils.add: Remove BuildRoot. * cpukit/Makefile.am: Use $(top_builddir)/common/common.add, $(top_builddir)/common/clean.add, header.add. Generate rtems-cpukit.spec.in. * cpukit/header.add: New. * cpukit/rtems-cpukit.spec.in: Remove. * cpukit/rtems-cpukit.add: New. * gccnewlib/gccnewlib.add: Remove Buildroot. * gdb/gdb.add: Remove Buildroot. * rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* 2003-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-313-105/+11
| | | | | | | | | | | | | | | | | | * rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add, $(top_builddir)/common/clean.add, header.add. Generate rtemsdoc.spec.in. * rtemsdoc/mkspec.in: Remove exe_ext. * rtemsdoc/rtemsdoc.spec.in: Remove. * gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add, $(top_builddir)/common/clean.add, header.add. * gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}. * gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}. Remove header, broken cdn-X configuration, %clean. * gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* 2003-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-312-0/+92
| | | | | | | | | | | * gcc3newlib/header.add: New. * gccnewlib/header.add: New. * binutils/header.add: New. * gdb/header.add: New. * rtemsdoc/header.add: New. * rtemsdoc/rtemsdoc.add: New. * common/clean.add.in: New. * common/common.add.in: New.
* 2003-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-262-0/+41
| | | | | | | * configure.ac: Add rtemsdoc. * Makefile.ac: Add rtemsdoc. * rtemsdoc/README: New. * rtemsdoc/.cvsignore: New.
* 2003-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-265-0/+284
* rtemsdoc/Makefile.am: New. * rtemsdoc/mkspec.in: New. * rtemsdoc/rtemsdoc.spec.in: New. * rtemsdoc/supplement.add.in: New. * rtemsdoc/templ.add.in: New.
