* configure.ac: chmod +x rtems/mkspec.
* binutils/binutils.add: Remove Prefix.
Use mkdir -p.
* cpukit/rtems-cpukit.add: Fix Source URL.
* rtems/Makefile.am: Append @osversion@ to rules.
* rtems/rtems.add: Fix Source URL. Misc cosmetics.
* rtems/Makefile.am: Reworked.
* buildall.in, buildalltar.in, binutils/Makefile.am,
cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/gccnewlib.add,
gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore,
rtemsdoc/Makefile.am: i960 obsoleted.
* configure.ac: Remove rtemsdoc/mkspec. Add RTEMS_RPM_RELEASE.
* rtemsdoc/.cvsignore: Reformat.
* Makefile.am: Reformat. Add RTEMS_RPM_RELEASE support to
rtems-source.add, Use rtems_source_spec_DEPS instead of
rtems_source_spec_DEPENDENCIES (Conflicts with automake internals).
* rtems/rtems-source.add: Add RTEMS_RPM_RELEASE.
* rtemsdoc/mkspec.in: Remove.
* rtemsdoc/Makefile.am: Reworked.
* rtemsdoc/header.add: Update Copyright notice.
* rtemsdoc/rtemsdoc.add: Add RTEMS_RPM_RELEASE.
Add %{rpmgroup}. Remove bzip-ing *.ps.
* rtemsdoc/supplement.add.in: Add %{rpmgroup}.
* rtemsdoc/templ.add.in: Add %{rpmgroup}.
* rtems/rtems-source.add: Require automake-1.8.2, autoconf-2.59.
* rtems/rtems-source.add: New.
* Makefile.am: Add rtems/rtems-source.spec handling.
* configure.ac: AC_SUBST(RTEMS_VERSION,[_RTEMS_VERSION]).
* common/common.add.in: Use www.rtems.com as Vendor.
cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am,
rtemsdoc/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* Makefile.am: Cosmetics.
* autotools/Makefile.am: Cosmetics.
* autotools/autoconf-rtems.spec.in: 2.59.
* autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59.
* binutils/Makefile.am: Cosmetics.
* cpukit/Makefile.am: Cosmetics.
* gcc3newlib/Makefile.am: Cosmetics.
* gccnewlib/Makefile.am: Cosmetics.
* gdb/Makefile.am: Cosmetics.
* rtems/Makefile.am: Cosmetics.
* rtemsdoc/Makefile.am: Cosmetics.
rtemsdoc/Makefile.am: Obsoleting HP PA-RISC port.
* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
binutils/target-binutils.add,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gdb/Makefile.am,
rtems/Makefile.am,
Merger from rtems-4-6-branch.
* common/common.am: New.
* setup.def: Updated to binutils 2.12.1.
* rtems/Makefile.am: Remove m68k-rtemself references.
* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
not right yet.
Now can specify rpm_build_root via setup.
issue and has mkbspspec in a better state. user.cfg is now
gone.
There are some miscellaneous changes to buildall done by Joel
to clean up the build process.
