* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+3 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -0/+4 |
| | | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups | ||||
* | RTEMS RPM basically working. | Joel Sherrill | 1999-11-22 | 1 | -9/+12 |
* | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1999-10-21 | 1 | -1/+13 |
* | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1999-10-21 | 1 | -1/+1 |
| | | | | | | not right yet. Now can specify rpm_build_root via setup. | ||||
* | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 1999-10-21 | 1 | -17/+25 |
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 1 | -27/+26 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Shipping this all to Ralf. | Joel Sherrill | 1999-10-21 | 1 | -1/+2 |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+50 |
* | Moved rtems specific files into here. | Joel Sherrill | 1999-10-20 | 1 | -0/+80 |
