* | 2003-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-02 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in, binutils/Makefile.am, binutils/base-binutils.add, binutils/binutils.add, binutils/mkspec.in, binutils/target-binutils.add, common/common.add.in, cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/base-g77.add, gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add, gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, gcc3newlib/target-c++.add, gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add, gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add, gcc3newlib/target-objc.add, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/Makefile.am: Merger from rtems-4-6-branch. * common/common.am: New. | ||||
* | 2001-05-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-05-29 | 1 | -1/+0 |
| | | | | | * setup.def: Updated to binutils 2.12.1. * rtems/Makefile.am: Remove m68k-rtemself references. | ||||
* | 2001-04-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-16 | 1 | -3/+0 |
| | | | | | | | | * .cvsignore: Added files added by automake 1.6.1. * setup.def: New shot at gcc 3.0.4 RPMs. * binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am: Deleted m68k-rtemself. * gcc3newlib/gccnewlib.add: Commented out host/target OS check. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * autotools/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * binutils/Makefile.am: Remove AUTOMAKE_OPTIONS. * gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS. * gdb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 3 | -20/+16 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+3 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -0/+4 |
| | | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups | ||||
* | RTEMS RPM basically working. | Joel Sherrill | 1999-11-22 | 1 | -9/+12 |
* | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1999-10-21 | 1 | -1/+13 |
* | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1999-10-21 | 1 | -1/+1 |
| | | | | | | not right yet. Now can specify rpm_build_root via setup. | ||||
* | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 1999-10-21 | 1 | -17/+25 |
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 1 | -27/+26 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Shipping this all to Ralf. | Joel Sherrill | 1999-10-21 | 1 | -1/+2 |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+50 |
* | Moved rtems specific files into here. | Joel Sherrill | 1999-10-20 | 1 | -0/+80 |
