* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
not right yet.
Now can specify rpm_build_root via setup.
issue and has mkbspspec in a better state. user.cfg is now
gone.
There are some miscellaneous changes to buildall done by Joel
to clean up the build process.
