path: root/scripts/mkgdbspec.in (follow)
* Made the RTEMS version get substituted properly even though it isJoel Sherrill1999-10-211-0/+1
| | | | | | not right yet. Now can specify rpm_build_root via setup.
* Changes from Ralf with script-19991021-0. He fixed the %filesJoel Sherrill1999-10-211-3/+4
| | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process.
* Miscellaneous improvements and cleanups committed so I can mergeJoel Sherrill1999-10-201-4/+1
| | | | Ralf's end of day version.
* Generated files removed.Joel Sherrill1999-10-201-2/+3
* Made this more binutils like. :)Joel Sherrill1999-10-201-5/+9
* Adding the infrastructure for gdb.Joel Sherrill1999-10-201-0/+67
