1999-10-20 | Generated files removed. | Joel Sherrill | 1 | -64/+0 | |
1999-10-20 | Adding the infrastructure for gdb. | Joel Sherrill | 1 | -1/+1 | |
1999-10-20 | New version from Ralf. | Joel Sherrill | 1 | -22/+41 | |
1999-10-19 | Easier to insert tool version number. | Joel Sherrill | 1 | -9/+20 | |
1999-10-18 | Working on being able to cut RPMs. It now appears that the process | Joel Sherrill | 1 | -5/+6 | |
is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets. | |||||
1999-10-15 | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 1 | -0/+33 | |
help build RPMs. |
