by all targets and one or more target specific RPMs. This significantly
reduces the conflicts between the RPMs whether installing one or multiple
targets.
Cygwin support to the RPM scripts. The patch from David did not
apply cleanly and Joel ended up making all the modifications
plus some it should have included for consistency by hand. His comments:
I've included a diff against the last (19991203) snapshot RPM scripts that
adds what I think is required for Cygwin support. Basically all this boils
down to is adding EXE extension support. I've added the AC_EXEEXT rule to
conifgure.in (requires a valid 'cc' to work - this is not available in the
standard Cygwin distro). Each of the *.spec.in have @exe_ext@ includes in
them for each program that results in an EXE. The only odity here is that
the chill driver program is a shell script and thus does not require .exe to
be added... The mk*.in have all been updated to process the new exe_ext
rule.
BSP needs to be eliminated.
not right yet.
Now can specify rpm_build_root via setup.
issue and has mkbspspec in a better state. user.cfg is now
gone.
There are some miscellaneous changes to buildall done by Joel
to clean up the build process.
Ralf's end of day version.
is working mostly for sparc at least.
There is one major problem -- the current process generates a unique
source file per RPM when in fact all of the source files are nearly
the same -- it is only the spec part of the rpm which differs.
The new file mkbinutils_subpackage_version is an attempt to
address this. It does part of the job right -- one source file
produces multiple binary RPMs. BUT the end user can not produce
the resulting RPMS themselves from SRPMS unless they also
build all targets.
help build RPMs.
