BSP needs to be eliminated.
not right yet.
Now can specify rpm_build_root via setup.
issue and has mkbspspec in a better state. user.cfg is now
gone.
There are some miscellaneous changes to buildall done by Joel
to clean up the build process.
Ralf's end of day version.
