* | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1999-10-21 | 1 | -0/+1 |
| | | | | | | not right yet. Now can specify rpm_build_root via setup. | ||||
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 1 | -3/+3 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 1999-10-20 | 1 | -4/+1 |
| | | | | Ralf's end of day version. | ||||
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 1 | -0/+64 |
