1999-10-21 | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1 | -3/+4 | |
not right yet. Now can specify rpm_build_root via setup. | |||||
1999-10-21 | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1 | -22/+50 | |
issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | |||||
1999-10-20 | Moving things to an rtems subdirectory like the other tools. | Joel Sherrill | 1 | -0/+0 | |
1999-10-15 | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 1 | -0/+31 | |
help build RPMs. |
