1999-10-26 | Regenerated | Joel Sherrill | 1 | -5/+6 | |
1999-10-25 | Patch generated from scripts-19991025-0.tar.gz from | Joel Sherrill | 2 | -8/+5 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages) | |||||
1999-10-25 | Regnenerated following update from Ralf. | Joel Sherrill | 1 | -5/+6 | |
1999-10-25 | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 2 | -16/+10 | |
1999-10-21 | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1 | -3/+15 | |
1999-10-21 | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 2 | -1/+3 | |
not right yet. Now can specify rpm_build_root via setup. | |||||
1999-10-21 | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 2 | -39/+48 | |
1999-10-21 | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 3 | -23/+28 | |
issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | |||||
1999-10-20 | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1 | -0/+1 | |
functioned. | |||||
1999-10-20 | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 1 | -1/+2 | |
Ralf's end of day version. | |||||
1999-10-20 | Generated files removed. | Joel Sherrill | 1 | -23/+28 | |
1999-10-20 | New file. | Joel Sherrill | 1 | -0/+104 | |
1999-10-20 | New files. | Joel Sherrill | 2 | -0/+285 | |
