* binutils/binutils.add: Use BuildRequires instead of BuildPreReq.
* gccnewlib/gccnewlib.add: Use BuildRequires instead of BuildPreReq.
* gdb/gdb.add: Use BuildRequires instead of BuildPreReq.
* gccnewlib/gccnewlib.add: Remove Source0-magic for gcc < 3.0.
* gdb/gdb.add: Propagate RPM_OPT_FLAGS to configure.
* gdb/base-gdb.add, gdb/gdb.add, gdb/target-gdb.add:
Use mkdir -p. Introduce %{_includedir}, %{_libdir}. Remove
superfluous %doc.
* gdb/mkspec.in: Remove extra_configure_arguments (Unused).
* gdb/Makefile.am: Remove obsolete targets.
* gdb/gdb.add: Pass bindir, infodir, mandir to configure.
* gdb/gdb.add, gdb/target-gdb.add: Introduce %{_infodir}, %{_mandir},
%{_bindir}. Various minor fixes.
Rename src.rpm into <target>-gdb.
Disable sim for avr.
* setup.def, gdb/gdb.add: Add gdb_suffix.
* cpukit/rtems-cpukit.add, gdb/gdb.add:
Fix my email address, cosmetics.
* binutils/target-binutils.add, cpukit/rtems-cpukit.add,
gcc3newlib/gccnewlib.add, gdb/gdb.add, rtemsdoc/rtemsdoc.add:
Remove Autoreqprov-tag.
* gdb/Makefile.am: Add avr, mips64.
Cosmetics.
* gdb/base-gdb.add: Reflect gdb-6.3 not shipping mmalloc.info*.
* gdb/target-gdb.add: Add support for gcc-6.3's gdbtui.
* gdb/mkspec.in: Add PATCH-magic.
Add gdb_suffix.
* buildall.in, buildalltar.in, binutils/Makefile.am,
cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/gccnewlib.add,
gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore,
rtemsdoc/Makefile.am: i960 obsoleted.
* gdb/base-gdb.add: Add annotate.info.
* gdb/gdb.add: Remove info/dir.
* Makefile.am, gdb/Makefile.am: Cosmetics.
* setup.def, gdb/gdb.add: gdb 6.0 RPMs built.
* setup.def, gdb/base-gdb.add, gdb/gdb.add: Building a gcc 3.2.3 i960
gcc and updating gdb to 5.3.
cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am,
gdb/Makefile.am: Attempt to convert all c4x-rtems references to
tic4x-rtems. Left the rtems documentation alone.
rtemsdoc/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* Makefile.am: Cosmetics.
* autotools/Makefile.am: Cosmetics.
* autotools/autoconf-rtems.spec.in: 2.59.
* autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59.
* binutils/Makefile.am: Cosmetics.
* cpukit/Makefile.am: Cosmetics.
* gcc3newlib/Makefile.am: Cosmetics.
* gccnewlib/Makefile.am: Cosmetics.
* gdb/Makefile.am: Cosmetics.
* rtems/Makefile.am: Cosmetics.
* rtemsdoc/Makefile.am: Cosmetics.
rtemsdoc/Makefile.am: Obsoleting HP PA-RISC port.
* binutils/base-binutils.add: Add osversion support.
* binutils/binutils.add: Add osversion support.
%setup -n %{name}-%{version}.
Don't remove c++filt.
* binutils/target-binutils.add: Add osversion support.
Pickup c++filt.
* gcc3newlib/base-g77.add: Add osversion support.
* gcc3newlib/base-gcc.add: Add osversion support.
* gcc3newlib/base-gcj.add: Add osversion support.
* gcc3newlib/base-gnat.add: Add osversion support.
* gcc3newlib/gccnewlib.add: Add osversion support.
Remove c++filt,
%setup -n -n %{name}-%{version}.
* gcc3newlib/target-c++.add: Add osversion support.
Don't pickup c++filt.
* gcc3newlib/target-g77.add: Add osversion support.
* gcc3newlib/target-gcc.add: Add osversion support.
* gcc3newlib/target-gcj.add: Add osversion support.
* gcc3newlib/target-gnat.add: Add osversion support.
* gccnewlib/gccnewlib.add: %setup -n %{name}-%{version}.
* gdb/base-gdb.add: Add osversion support, rpmgroup, rpmprefix,
gdb_version, gdb_target.
* gdb/target-gdb.add: Ditto.
* gdb/gdb.add: Ditto.
* configure.ac: Add --enable-osversions (OS-versioned RPMS support).
* binutils/Makefile.am: Add osversion support.
* binutils/mkspec.in: Add osversion support.
* gcc3newlib/Makefile.am: Add osversion support.
* gcc3newlib/mkspec.in: Add osversion support.
* gdb/Makefile.am: Add osversion support.
* gdb/mkspec.in: Add osversion support.
Add rpmprefix, rpmgroup.
* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gdb/Makefile.am,
rtems/Makefile.am,
Merger from rtems-4-6-branch.
* common/common.am: New.
* setup.def: Updated gdb revision to -2 so arm will build and
to fix psim build problem on NetBSD.
* gcc3newlib/gccnewlib.add: Ignore dependency on GNAT RPM since
RedHat 7.3 doesn't have it available. Maybe later.
* gdb/Makefile.am: Cleanup way the RPM_SPECS_DATA variable is built.
* gdb/gdb.add, gdb/mkspec.in, gdb/target-gdb.add: Use RPM logic to
determine which targets have simulators, configure with appropriate
arguments, and package the correct files.
* Apply the 2003-01-31 changes OAR's broken CVS had dropped.
* common/common.add.in: Add Vendor, Distribution, BuildRoot.
* binutils/Makefile.am: Fix path to clean.add.
* binutils/binutils.add: Remove BuildRoot.
* cpukit/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtems-cpukit.spec.in.
* cpukit/header.add: New.
* cpukit/rtems-cpukit.spec.in: Remove.
* cpukit/rtems-cpukit.add: New.
* gccnewlib/gccnewlib.add: Remove Buildroot.
* gdb/gdb.add: Remove Buildroot.
* rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* gdb/gdb.add: Remove header, broken cdn-X configuration,
%clean, Replace @exe_ext@ with %{_exeext}.
* gdb/mkspec.in: Remove exe_ext.
* gdb/target-gdb.add: Replace @exe_ext@ with %{_exeext}.
* gdb/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* cpukit/mkspec.in: Remove exe_ext.
* binutils/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/header.add: New.
* gccnewlib/header.add: New.
* binutils/header.add: New.
* gdb/header.add: New.
* rtemsdoc/header.add: New.
* rtemsdoc/rtemsdoc.add: New.
* common/clean.add.in: New.
* common/common.add.in: New.
* binutils/mkspec.in: New.
* binutils/.cvsignore: Add mkspec.
* mkbinutilspec.in: Remove.
* gdb/Makefile.am: Depend on mkspec.
* binutils/binutils.add: Add @exe_ext@ to c++filt.
Add %_defaultbuildroot.
* gdb/.cvsignore: Add mkspec.
* ChangeLog: Fix yesterday's entry.
* gdb/target-gdb.add: %defattr(-,root,root).
Use %{_prefix} instead of /opt/rtems.
Misc. minor changes.
* gdb/gdb.add: Use %{_prefix} instead of /opt/rtems.
Remove stray unpackaged files.
Use %{_defaultbuildroot} instead of hard-coded values.
configure --disable-nls.
Add BuildPreReq: ncurses-devel.
* gdb/base-gdb.add: %defattr(-,root,root).
* gdb/mkspec.in: New.
* gdb/Makefile.am: Reflect addition of gdb/mkspec.in.
* gcc3newlib/mkspec.in: Fix usage.
* gcc3newlib/gccnewlib.add: Use %{_defaultbuildroot} instead of
hard-coded values. Update copyright notice.
* mkgdbspec.in: Removed.
* Makefile.am: Remove mkgdbspec.
* configure.ac: Remove mkgdbspec.
Add gdb/mkspec.
* mkgdbspec.in, setup.def, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Updated to gcc 3.1 and gdb 5.2.
* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* setup.def: Bumped the gdb_patch_version to account for a configuration
problem on psim where it could not be enabled for powerpc-RTEMS.
* gdb/Makefile.am: Add i386-RTEMS and powerpc-RTEMS targets.
* gdb/Makefile.am, gccnewlib/Makefile.am, binutils/Makefile.am:
Initially setup CLEANFILES using = instead of += to make
automake-1.5 happy.
* gdb/Makefile.am, mkgdbspec.in: Added mipstx39-rtems
configuration to gdb since this includes the JMR3904 simulator.
* buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am,
gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am:
Added mips-rtems, updated to include new patches and
gcc 2.95.2/newlib 1.8.2 revision 11 RPM.
