* | 2005-10-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-31 | 2 | -7/+8 |
| | | | | | | * gccnewlib/gccnewlib.add: Rename src.rpm to *-gcc.src.rpm. * gccnewlib/target-gcc.add: Reflect changes above. * gccnewlib/Makefile.am: Re-sort sub-package fragments. | ||||
* | 2005-09-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-15 | 1 | -0/+2 |
| | | | | | * gccnewlib/gccnewlib.add: Pass CC="%__cc $RPM_OPT_FLAGS" to configure. | ||||
* | Append %_bindir to PATH only if %_prefix != /usr. | Ralf Corsepius | 2005-09-15 | 1 | -0/+2 |
* | Generate unversioned *gcc-newlib.spec. | Ralf Corsepius | 2005-09-15 | 1 | -24/+24 |
* | Rename *.spec into @rpmprefix@*.spec. | Ralf Corsepius | 2005-09-02 | 1 | -24/+24 |
* | Replace %{rpmprefix} with @rpmprefix@ | Ralf Corsepius | 2005-09-02 | 14 | -68/+68 |
* | 2005-09-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-02 | 4 | -18/+26 |
| | | | | | | * gccnewlib/Makefile.am: Use target-libc.add * gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add, gccnewlib/target-libc.add: Misc. fixes. | ||||
* | Switch to using %gcc_version. | Ralf Corsepius | 2005-09-01 | 10 | -10/+18 |
* | Fix directory ownerships. | Ralf Corsepius | 2005-09-01 | 6 | -1/+23 |
* | 2005-08-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-31 | 1 | -0/+18 |
| | | | | * gccnewlib/target-libc.add: New. | ||||
* | Remove dep on *-base-gfortran for prefix=/usr. | Ralf Corsepius | 2005-08-30 | 1 | -0/+2 |
* | Remove dep on *-base-gcc for prefix=/usr. | Ralf Corsepius | 2005-08-30 | 1 | -0/+2 |
* | Cosmetics. | Ralf Corsepius | 2005-08-30 | 2 | -3/+3 |
* | Cosmetics. | Ralf Corsepius | 2005-08-30 | 3 | -3/+7 |
* | 2005-08-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-30 | 1 | -4/+6 |
| | | | | * gccnewlib/target-gcc.add: Add Requires/Provides *-newlib/*-libc. | ||||
* | cleanups | Ralf Corsepius | 2005-08-30 | 1 | -0/+14 |
* | Minor cleanups. | Ralf Corsepius | 2005-08-30 | 1 | -1/+1 |
* | Use gccnewlib_version. Cosmetics. Minor cleanups. | Ralf Corsepius | 2005-08-30 | 9 | -27/+26 |
* | Remove _includedir | Ralf Corsepius | 2005-08-30 | 1 | -2/+0 |
* | Remove %_bindir. | Ralf Corsepius | 2005-08-30 | 2 | -2/+0 |
* | Remove %_bindir. | Ralf Corsepius | 2005-08-30 | 1 | -5/+6 |
| | | | | Add %{gcc_target}-gfortran.1. | ||||
* | Remove %_bindir. | Ralf Corsepius | 2005-08-30 | 1 | -3/+0 |
| | | | | Remove %_mandir. | ||||
* | Add %{gcc_target}-g77.1. | Ralf Corsepius | 2005-08-30 | 1 | -1/+2 |
* | Remove Packager:. | Ralf Corsepius | 2005-08-30 | 1 | -4/+3 |
| | | | | Add %gccnewlib_version. | ||||
* | Remove %_mandir. | Ralf Corsepius | 2005-08-30 | 1 | -6/+2 |
| | | | | Remove %{gcc_target}-gfortran.1. | ||||
* | Remove %_mandir. | Ralf Corsepius | 2005-08-30 | 1 | -4/+0 |
| | | | | Remove %{gcc_target}-g77.1. | ||||
* | 2005-08-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-25 | 1 | -1/+8 |
| | | | | | * gccnewlib/gccnewlib.add: Remove vxaddr2line. Further minor cleanup. | ||||
* | Special-case _prefix == /usr | Ralf Corsepius | 2005-08-17 | 6 | -0/+18 |
* | Remove h8300-rtemscoff | Ralf Corsepius | 2005-08-15 | 1 | -4/+0 |
* | Reflect using brp-rtems*. | Ralf Corsepius | 2005-07-28 | 1 | -11/+15 |
* | 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-05 | 1 | -11/+11 |
| | | | | | * binutils/mkspec.in, gccnewlib/mkspec.in, gdb/mkspec.in: Use ',' as sed pattern delimiter. | ||||
* | 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-05 | 1 | -1/+0 |
| | | | | * gccnewlib/gccnewlib.add: Remove Epoch. | ||||
* | Correct PATCH<N> handling. | Ralf Corsepius | 2005-05-20 | 1 | -3/+3 |
* | Remove bogus comment | Ralf Corsepius | 2005-05-20 | 1 | -10/+0 |
* | install-info --info-dir= | Ralf Corsepius | 2005-05-20 | 5 | -28/+28 |
* | Document --with/--without. | Ralf Corsepius | 2005-05-18 | 1 | -1/+11 |
* | Reflect changes to mkspec.in. | Ralf Corsepius | 2005-05-18 | 1 | -37/+55 |
| | | | | Use --with/--without, rework logic for building optional languages. | ||||
* | Correct patch handling magic. | Ralf Corsepius | 2005-05-18 | 1 | -5/+2 |
* | 2005-05-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-10 | 2 | -5/+6 |
| | | | | | | * gccnewlib/Makefile.am: Add h8300-rtemscoff*. * gccnewlib/gccnewlib.add: Let building gnat require gcc. Allow building arm-rtems*-gnat. | ||||
* | 2005-05-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-05 | 2 | -22/+17 |
| | | | | | | * gccnewlib/gccnewlib.add: Further clean up of tools not supported by individual targets. Add %build_libgcj. * gccnewlib/target-gcc.add: Remove dep to base-gcc. | ||||
* | 2005-05-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-03 | 1 | -6/+11 |
| | | | | | * gccnewlib/gccnewlib.add: Suppress building tools not supported by avr, h8300 and mips. | ||||
* | Misc. %infodir/dir handling changes. | Ralf Corsepius | 2005-05-03 | 5 | -25/+20 |
* | 2005-05-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-03 | 1 | -8/+1 |
| | | | | | * gccnewlib/gccnewlib.add: Remove gnatgcc hacks. Misc %infodir/dir handling changes. | ||||
* | Requires: %{rpmprefix}%{gcc_target}-gcc = %{version}-%{release}. | Ralf Corsepius | 2005-05-03 | 6 | -6/+11 |
* | 2005-04-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-29 | 1 | -6/+0 |
| | | | | | | | * gccnewlib/gccnewlib.add: Don't build mips-gcj. Further gnat cleanup. * rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc. info fixes. | ||||
* | 2005-04-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-29 | 3 | -46/+1 |
| | | | | | * gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add, gccnewlib/target-gnat.add: Abandon Gnat for gcc < 4.0 | ||||
* | 2005-04-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-27 | 3 | -18/+20 |
| | | | | | | * gccnewlib/base-gfortran.add: Fix broken install-info. * gccnewlib/base-gnat.add, gccnewlib/target-gnat.add: Adaptations to gcc-4.0.0. Install infos using FC conventions. | ||||
* | 2005-04-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-26 | 4 | -46/+70 |
| | | | | | | | | * gccnewlib/base-gcc.add: Install infos using FC conventions. * gccnewlib/base-gcj.add: Install infos using FC conventions. Various minor fixes. * gccnewlib/base-gfortran.add: Install infos using FC conventions. * gccnewlib/target-gcj.add: Various minor fixes. | ||||
* | Fix another typo in previous patch | Ralf Corsepius | 2005-04-25 | 1 | -10/+0 |
* | 2005-04-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-25 | 1 | -11/+4 |
| | | | | | | | * binutils/binutils.add: Use BuildRequires instead of BuildPreReq. * gccnewlib/gccnewlib.add: Use BuildRequires instead of BuildPreReq. * gdb/gdb.add: Use BuildRequires instead of BuildPreReq. * gccnewlib/gccnewlib.add: Remove Source0-magic for gcc < 3.0. |
