* gccnewlib/Makefile.am: Add h8300-rtemscoff*.
* gccnewlib/gccnewlib.add: Let building gnat require gcc.
Allow building arm-rtems*-gnat.
* gccnewlib/gccnewlib.add: Further clean up of tools not supported
by individual targets. Add %build_libgcj.
* gccnewlib/target-gcc.add: Remove dep to base-gcc.
* gccnewlib/gccnewlib.add: Suppress building tools not supported by
avr, h8300 and mips.
* gccnewlib/gccnewlib.add: Remove gnatgcc hacks.
Misc %infodir/dir handling changes.
* gccnewlib/gccnewlib.add: Don't build mips-gcj. Further gnat
cleanup.
* rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc. info
fixes.
* gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/target-gnat.add: Abandon Gnat for gcc < 4.0
* gccnewlib/base-gfortran.add: Fix broken install-info.
* gccnewlib/base-gnat.add, gccnewlib/target-gnat.add: Adaptations
to gcc-4.0.0. Install infos using FC conventions.
* gccnewlib/base-gcc.add: Install infos using FC conventions.
* gccnewlib/base-gcj.add: Install infos using FC conventions.
Various minor fixes.
* gccnewlib/base-gfortran.add: Install infos using FC conventions.
* gccnewlib/target-gcj.add: Various minor fixes.
* binutils/binutils.add: Use BuildRequires instead of BuildPreReq.
* gccnewlib/gccnewlib.add: Use BuildRequires instead of BuildPreReq.
* gdb/gdb.add: Use BuildRequires instead of BuildPreReq.
* gccnewlib/gccnewlib.add: Remove Source0-magic for gcc < 3.0.
* gccnewlib/gccnewlib.add: Abandond c4x-*.
* gccnewlib/gccnewlib.add: Use %_bindir, %_libdir, %_includedir.
* gccnewlib/target-gfortran.add: Let package obsolete g77.
* gccnewlib/target-objc.add: Reflect new location of cc1obj.
* gccnewlib/base-gfortran.add, gccnewlib/target-gfortran.add: New.
* gccnewlib/Makefile.am: Reflect addition of gfortran.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add,
gccnewlib/base-gnat.add, gccnewlib/target-g++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
Remove RPM_INSTALL_PREFIX. Remove superfluous
%doc directives. Use %_infodir, %_includedir, %_bindir, %_libdir.
* gccnewlib/gccnewlib.add: Ditto.
Add further BR's, Reflect addition of gfortran.
Reflect gcc's changes to "version_string".
* gccnewlib/mkspec.in: Use gccnewlib/ instead of gcc3newlib/.
* mkgccnewlibspec.in, gccnewlib/.cvsignore, gccnewlib/HISTORY,
gccnewlib/Makefile.am, gccnewlib/README, gccnewlib/base-chill.add,
gccnewlib/gccnewlib.add, gccnewlib/header.add,
gccnewlib/target-chill.add, gccnewlib/target-g77.add,
gccnewlib/target-objc.add: Remove (Obsolete).
* configure.ac, Makefile.am: Reflect changes above.
* buildall.in, buildalltar.in, binutils/Makefile.am,
cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am,
gdb/Makefile.am: Attempt to convert all c4x-rtems references to
tic4x-rtems. Left the rtems documentation alone.
gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore,
rtemsdoc/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* Makefile.am: Cosmetics.
* autotools/Makefile.am: Cosmetics.
* autotools/autoconf-rtems.spec.in: 2.59.
* autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59.
* binutils/Makefile.am: Cosmetics.
* cpukit/Makefile.am: Cosmetics.
* gcc3newlib/Makefile.am: Cosmetics.
* gccnewlib/Makefile.am: Cosmetics.
* gdb/Makefile.am: Cosmetics.
* rtems/Makefile.am: Cosmetics.
* rtemsdoc/Makefile.am: Cosmetics.
rtemsdoc/Makefile.am: Obsoleting HP PA-RISC port.
* binutils/base-binutils.add: Add osversion support.
* binutils/binutils.add: Add osversion support.
%setup -n %{name}-%{version}.
Don't remove c++filt.
* binutils/target-binutils.add: Add osversion support.
Pickup c++filt.
* gcc3newlib/base-g77.add: Add osversion support.
* gcc3newlib/base-gcc.add: Add osversion support.
* gcc3newlib/base-gcj.add: Add osversion support.
* gcc3newlib/base-gnat.add: Add osversion support.
* gcc3newlib/gccnewlib.add: Add osversion support.
Remove c++filt,
%setup -n -n %{name}-%{version}.
* gcc3newlib/target-c++.add: Add osversion support.
Don't pickup c++filt.
* gcc3newlib/target-g77.add: Add osversion support.
* gcc3newlib/target-gcc.add: Add osversion support.
* gcc3newlib/target-gcj.add: Add osversion support.
* gcc3newlib/target-gnat.add: Add osversion support.
* gccnewlib/gccnewlib.add: %setup -n %{name}-%{version}.
* gdb/base-gdb.add: Add osversion support, rpmgroup, rpmprefix,
gdb_version, gdb_target.
* gdb/target-gdb.add: Ditto.
* gdb/gdb.add: Ditto.
* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
binutils/target-binutils.add,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gdb/Makefile.am,
rtems/Makefile.am,
Merger from rtems-4-6-branch.
* common/common.am: New.
* common/common.add.in: Add Vendor, Distribution, BuildRoot.
* binutils/Makefile.am: Fix path to clean.add.
* binutils/binutils.add: Remove BuildRoot.
* cpukit/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtems-cpukit.spec.in.
* cpukit/header.add: New.
* cpukit/rtems-cpukit.spec.in: Remove.
* cpukit/rtems-cpukit.add: New.
* gccnewlib/gccnewlib.add: Remove Buildroot.
* gdb/gdb.add: Remove Buildroot.
* rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add,
Generate rtemsdoc.spec.in.
* rtemsdoc/mkspec.in: Remove exe_ext.
* rtemsdoc/rtemsdoc.spec.in: Remove.
* gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add,
* gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}.
Remove header, broken cdn-X configuration, %clean.
* gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/header.add: New.
* gccnewlib/header.add: New.
* binutils/header.add: New.
* gdb/header.add: New.
* rtemsdoc/header.add: New.
* rtemsdoc/rtemsdoc.add: New.
* common/clean.add.in: New.
* common/common.add.in: New.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mkbinutilspec.in, mkgccnewlibspec.in, gccnewlib/base-chill.add,
gccnewlib/base-gcj.add, gccnewlib/gccnewlib.add,
gccnewlib/target-objc.add: Added more support for Canadian Cross
building.
* gdb/Makefile.am, gccnewlib/Makefile.am, binutils/Makefile.am:
Initially setup CLEANFILES using = instead of += to make
automake-1.5 happy.
* setup.def, gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add:
Revert changes because of gcc 2.5.x/3.0 transition and continue
to support gcc 2.95.x as primary version.
Use Target_alias not target_alias to avoid conflicts with new autoconf.
* setup.def: Changed version numbers in attempt at building gcc 3.0.1.
Only sparc and arm built for C/C++ OK. :(
* gccnewlib/base-gcc.add: Modifications to reflect files not in gcc 3.x.
* gccnewlib/gccnewlib.add: gcc 3.x does not have "everything in the name"
* target-gcc.add: Modifications to reflect files not in gcc 3.1
* setup.def, binutils.add, gccnewlib.add: Updated to build
binutils 2.11.2 (rtems patch 20010622), gcc 2.95.3 (rtems
patch a20010622), and newlib 1.9.0 (rtems patch 10020622).
* configure.in: Remove AC_EXEEXT, treat .exe manually.
* gccnewlib/base-gcc.add: Remove cpp.
* gccnewlib/gccnewlib.add: mv cpp $target_alias-cpp, update
copyright.
* setup.def, binutils/HISTORY, gccnewlib/HISTORY: Updated
binutils HISTORY to reflect new revision. Updated gcc to fix
i960 C++ problem. Updated newlib to move to newlib 1.9.0.
* gccnewlib/gccnewlib.add: Fix typo in URL.
* buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am,
gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am:
Added mips-rtems, updated to include new patches and
gcc 2.95.2/newlib 1.8.2 revision 11 RPM.
* setup.def: Updated gcc and newlib patches and bumped RPM revision.
Patches primarily add or16/or32 basic support to newlib and
i386 multilib improvements to gcc from Ralf Corsepius.
