* | Replace %{rpmprefix} with @rpmprefix@ | Ralf Corsepius | 2005-09-02 | 1 | -5/+5 |
* | Switch to using %gcc_version. | Ralf Corsepius | 2005-09-01 | 1 | -1/+2 |
* | Fix directory ownerships. | Ralf Corsepius | 2005-09-01 | 1 | -0/+4 |
* | Cosmetics. | Ralf Corsepius | 2005-08-30 | 1 | -0/+2 |
* | Use gccnewlib_version. Cosmetics. Minor cleanups. | Ralf Corsepius | 2005-08-30 | 1 | -4/+4 |
* | Remove %_bindir. | Ralf Corsepius | 2005-08-30 | 1 | -1/+0 |
* | Requires: %{rpmprefix}%{gcc_target}-gcc = %{version}-%{release}. | Ralf Corsepius | 2005-05-03 | 1 | -1/+2 |
* | 2005-04-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-29 | 1 | -3/+0 |
| | | | | | * gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add, gccnewlib/target-gnat.add: Abandon Gnat for gcc < 4.0 | ||||
* | 2005-04-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-27 | 1 | -1/+5 |
| | | | | | | * gccnewlib/base-gfortran.add: Fix broken install-info. * gccnewlib/base-gnat.add, gccnewlib/target-gnat.add: Adaptations to gcc-4.0.0. Install infos using FC conventions. | ||||
* | 2005-04-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-22 | 1 | -2/+2 |
| | | | | | | | | | | | | | | * gccnewlib/base-gfortran.add, gccnewlib/target-gfortran.add: New. * gccnewlib/Makefile.am: Reflect addition of gfortran. * gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add, gccnewlib/base-gnat.add, gccnewlib/target-g++.add, gccnewlib/target-g77.add, gccnewlib/target-gcc.add, gccnewlib/target-gcj.add, gccnewlib/target-gnat.add: Remove RPM_INSTALL_PREFIX. Remove superfluous %doc directives. Use %_infodir, %_includedir, %_bindir, %_libdir. * gccnewlib/gccnewlib.add: Ditto. Add further BR's, Reflect addition of gfortran. Reflect gcc's changes to "version_string". | ||||
* | New. | Ralf Corsepius | 2005-04-12 | 1 | -0/+23 |
