* | install-info --info-dir= | Ralf Corsepius | 2005-05-20 | 1 | -2/+2 |
* | Misc. %infodir/dir handling changes. | Ralf Corsepius | 2005-05-03 | 1 | -2/+3 |
* | 2005-04-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-27 | 1 | -1/+1 |
| | | | | | | * gccnewlib/base-gfortran.add: Fix broken install-info. * gccnewlib/base-gnat.add, gccnewlib/target-gnat.add: Adaptations to gcc-4.0.0. Install infos using FC conventions. | ||||
* | 2005-04-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-04-26 | 1 | -17/+7 |
| | | | | | | | | * gccnewlib/base-gcc.add: Install infos using FC conventions. * gccnewlib/base-gcj.add: Install infos using FC conventions. Various minor fixes. * gccnewlib/base-gfortran.add: Install infos using FC conventions. * gccnewlib/target-gcj.add: Various minor fixes. | ||||
* | New. | Ralf Corsepius | 2005-04-21 | 1 | -0/+44 |
