Remove %{gcc_target}-gfortran.1.
* gccnewlib/base-gfortran.add: Fix broken install-info.
* gccnewlib/base-gnat.add, gccnewlib/target-gnat.add: Adaptations
to gcc-4.0.0. Install infos using FC conventions.
* gccnewlib/base-gcc.add: Install infos using FC conventions.
* gccnewlib/base-gcj.add: Install infos using FC conventions.
Various minor fixes.
* gccnewlib/base-gfortran.add: Install infos using FC conventions.
* gccnewlib/target-gcj.add: Various minor fixes.
