* gccnewlib/base-gcc.add: Install infos using FC conventions.
* gccnewlib/base-gcj.add: Install infos using FC conventions.
Various minor fixes.
* gccnewlib/base-gfortran.add: Install infos using FC conventions.
* gccnewlib/target-gcj.add: Various minor fixes.
* gccnewlib/base-gfortran.add, gccnewlib/target-gfortran.add: New.
* gccnewlib/Makefile.am: Reflect addition of gfortran.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add,
gccnewlib/base-gnat.add, gccnewlib/target-g++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-gnat.add:
Remove RPM_INSTALL_PREFIX. Remove superfluous
%doc directives. Use %_infodir, %_includedir, %_bindir, %_libdir.
* gccnewlib/gccnewlib.add: Ditto.
Add further BR's, Reflect addition of gfortran.
Reflect gcc's changes to "version_string".
* mkgccnewlibspec.in, gccnewlib/.cvsignore, gccnewlib/HISTORY,
gccnewlib/Makefile.am, gccnewlib/README, gccnewlib/base-chill.add,
gccnewlib/gccnewlib.add, gccnewlib/header.add,
gccnewlib/target-chill.add, gccnewlib/target-g77.add,
gccnewlib/target-objc.add: Remove (Obsolete).
* configure.ac, Makefile.am: Reflect changes above.
* rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtemsdoc.spec.in.
* rtemsdoc/mkspec.in: Remove exe_ext.
* rtemsdoc/rtemsdoc.spec.in: Remove.
* gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add,
* gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}.
Remove header, broken cdn-X configuration, %clean.
* gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* mkbinutilspec.in, mkgccnewlibspec.in, gccnewlib/base-chill.add,
gccnewlib/base-gcj.add, gccnewlib/gccnewlib.add,
gccnewlib/target-objc.add: Added more support for Canadian Cross
building.
