path: root/scripts/gccnewlib/base-gcj.add (follow)
* 2003-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-311-3/+3
| | | | | | | | | | | | | | | | | | * rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add, $(top_builddir)/common/clean.add, header.add. Generate rtemsdoc.spec.in. * rtemsdoc/mkspec.in: Remove exe_ext. * rtemsdoc/rtemsdoc.spec.in: Remove. * gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add, $(top_builddir)/common/clean.add, header.add. * gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}. * gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}. Remove header, broken cdn-X configuration, %clean. * gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}. * gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-051-4/+4
| | | | | | | | | | * mkbinutilspec.in, mkgccnewlibspec.in, gccnewlib/base-chill.add, gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add, gccnewlib/gccnewlib.add, gccnewlib/target-chill.add, gccnewlib/target-g77.add, gccnewlib/target-gcc.add, gccnewlib/target-gcj.add, gccnewlib/target-objc.add: Added more support for Canadian Cross building.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-0/+20
* Added on 4.5 branchJoel Sherrill2000-05-281-0/+0
