path: root/scripts/gcc3newlib/target-objc.add (follow)
* 2003-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-021-6/+5
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in, binutils/Makefile.am, binutils/base-binutils.add, binutils/binutils.add, binutils/mkspec.in, binutils/target-binutils.add, common/common.add.in, cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/base-g77.add, gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add, gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, gcc3newlib/target-c++.add, gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add, gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add, gcc3newlib/target-objc.add, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/Makefile.am: Merger from rtems-4-6-branch. * common/common.am: New.
* 2003-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-241-10/+10
| | | | | | | | | | | | | | | | | | | | | | | | * common/common.add.in: s/www.oarcorp.com/www.rtems.com/. Add %define __os_install_post %{nil} to prevent RH-9's rpm-brp-strip from running (Chokes on foreign object formats). * gcc3newlib/base-g77.add: Use %{gcc_version} instead of @gcc_version@. * gcc3newlib/gccnewlib.add: Use %{gcc_version} instead of @gcc_version@. Reflect gcc >= 3.3 shipping monolytic infos. * gcc3newlib/target-c++.add: Use %{gcc_version} instead of @gcc_version@. Don't pickup c++filt. * gcc3newlib/target-g77.add: Use %{gcc_version} instead of @gcc_version@. * gcc3newlib/target-gcc.add: Use %{gcc_version} instead of @gcc_version@. * gcc3newlib/target-gcj.add: Use %{gcc_version} instead of @gcc_version@. * gcc3newlib/target-gnat.add: Use %{gcc_version} instead of @gcc_version@. * gcc3newlib/target-objc.add: Use %{gcc_version} instead of @gcc_version@.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-2/+2
* 2003-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-311-1/+1
| | | | | | | | | | | | | | * gcc3newlib/gccnewlib.add: Remove header, broken cdn-X configuration, %clean, Replace @exe_ext@ with %{_exeext}. * gcc3newlib/mkspec.in: Remove exe_ext. * gcc3newlib/target-c++.add: Replace @exe_ext@ with %{_exeext}. * gcc3newlib/target-g77.add: Replace @exe_ext@ with %{_exeext}. * gcc3newlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}. * gcc3newlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}. * gcc3newlib/target-gnat.add: Replace @exe_ext@ with %{_exeext}. * gcc3newlib/target-objc.add: Replace @exe_ext@ with %{_exeext}. + gcc3newlib/Makefile.am: Use $(top_builddir)/common/common.add, $(top_builddir)/common/clean.add, header.add.
* 2003-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-281-0/+1
| | | | | | | | | | | | | | | * gccnewlib.add: Add various BuildPreReq. Add %defattr(-,root,root) to "dir". * base-g77.add: %defattr(-,root,root). * base-gcc.add %defattr(-,root,root). * base-gcj.add %defattr(-,root,root). * base-gnat.add %defattr(-,root,root). * target-c++.add %defattr(-,root,root). * target-g77.add %defattr(-,root,root). * target-gcc.add %defattr(-,root,root). * target-gcj.add %defattr(-,root,root). * target-gnat.add %defattr(-,root,root). * target-objc.add %defattr(-,root,root).
* 2002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-121-0/+2
| | | | | | | | | | | | | | | | | * mkgcc3newlibspec.in: Remove * gcc3newlib/mkspec.in: New. * configure.ac: Reflect changes above. * gcc3newlib/gccnewlib.add: Add build_XXX defines. Add preliminary gnat support. * gcc3newlib/base-g77.add: Add build_g77. * gcc3newlib/base-gcj.add: Add build_gcj. * gcc3newlib/base-gnat.add: New. * gcc3newlib/target-c++.add: Add build_cxx. * gcc3newlib/target-g77.add: Add build_g77. * gcc3newlib/target-gcj.add: Add build_gcj. * gcc3newlib/target-objc.add: Add build_objc. * gcc3newlib/target-gnat.add: New. * gcc3newlib/Makefile.am: Use ./mkspec. Use unified spec.
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-281-0/+17
* Per PR64 added support for gcc 3.x RPMs * Makefile.am, configure.ac, mkspec, setup, setup.def: Modified. * mkgcc3newlibspec.in: New file. * gcc3newlib: New subdirectory. * base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add, gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am, README, target-g77.add, target-gcc.add, target-gcj.add, target-objc.add: New files.
