* | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-09-14 | 1 | -0/+4 |
| | | | | | * gcc3newlib/base-gcj.add, gcc3newlib/gccnewlib.add, gcc3newlib/target-gcj.add: First attempt at enabling Java support. | ||||
* | 2002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-12 | 1 | -0/+2 |
| | | | | | | | | | | | | | | | | | * mkgcc3newlibspec.in: Remove * gcc3newlib/mkspec.in: New. * configure.ac: Reflect changes above. * gcc3newlib/gccnewlib.add: Add build_XXX defines. Add preliminary gnat support. * gcc3newlib/base-g77.add: Add build_g77. * gcc3newlib/base-gcj.add: Add build_gcj. * gcc3newlib/base-gnat.add: New. * gcc3newlib/target-c++.add: Add build_cxx. * gcc3newlib/target-g77.add: Add build_g77. * gcc3newlib/target-gcj.add: Add build_gcj. * gcc3newlib/target-objc.add: Add build_objc. * gcc3newlib/target-gnat.add: New. * gcc3newlib/Makefile.am: Use ./mkspec. Use unified spec. | ||||
* | 2001-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-03-28 | 1 | -0/+21 |
* Per PR64 added support for gcc 3.x RPMs * Makefile.am, configure.ac, mkspec, setup, setup.def: Modified. * mkgcc3newlibspec.in: New file. * gcc3newlib: New subdirectory. * base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add, gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am, README, target-g77.add, target-gcc.add, target-gcj.add, target-objc.add: New files. |
