* gcc3newlib/gccnewlib.add: Make not building gnat and gcj the
default for gcc-3.3.
* gcc3newlib/Makefile.am: Add tic4x.
* gcc3newlib/gccnewlib.add: Don't install install-tools for
gcc >= 3.3.
* gcc3newlib/gccnewlib.add: Fix duplicate removal of c++filt.
* gcc3newlib/base-gcj.add: Add fastjar.info, jar.1, grepjar.1.
* setup.def: gcc3newlib_rpm_release=4.
* binutils/base-binutils.add: Add osversion support.
* binutils/binutils.add: Add osversion support.
%setup -n %{name}-%{version}.
Don't remove c++filt.
* binutils/target-binutils.add: Add osversion support.
Pickup c++filt.
* gcc3newlib/base-g77.add: Add osversion support.
* gcc3newlib/base-gcc.add: Add osversion support.
* gcc3newlib/base-gcj.add: Add osversion support.
* gcc3newlib/base-gnat.add: Add osversion support.
* gcc3newlib/gccnewlib.add: Add osversion support.
Remove c++filt,
%setup -n -n %{name}-%{version}.
* gcc3newlib/target-c++.add: Add osversion support.
Don't pickup c++filt.
* gcc3newlib/target-g77.add: Add osversion support.
* gcc3newlib/target-gcc.add: Add osversion support.
* gcc3newlib/target-gcj.add: Add osversion support.
* gcc3newlib/target-gnat.add: Add osversion support.
* gccnewlib/gccnewlib.add: %setup -n %{name}-%{version}.
* gdb/base-gdb.add: Add osversion support, rpmgroup, rpmprefix,
gdb_version, gdb_target.
* gdb/target-gdb.add: Ditto.
* gdb/gdb.add: Ditto.
* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
binutils/target-binutils.add,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gccnewlib/Makefile.am,
gdb/Makefile.am,
rtems/Makefile.am,
rtemsdoc/Makefile.am:
Merger from rtems-4-6-branch.
* common/common.am: New.
* common/common.add.in: s/www.oarcorp.com/www.rtems.com/.
Add %define __os_install_post %{nil} to prevent RH-9's rpm-brp-strip
from running (Chokes on foreign object formats).
Use %{gcc_version} instead of @gcc_version@.
Reflect gcc >= 3.3 shipping monolytic infos.
* gcc3newlib/target-objc.add:
* setup.def: Update to gcc3.2.2newlib1.11.0-2.
* gcc3newlib/gccnewlib.add: We used .bz2 files.
* setup.def: Updated gdb revision to -2 so arm will build and
to fix psim build problem on NetBSD.
* gcc3newlib/gccnewlib.add: Ignore dependency on GNAT RPM since
RedHat 7.3 doesn't have it available. Maybe later.
* gdb/Makefile.am: Cleanup way the RPM_SPECS_DATA variable is built.
* gcc3newlib/target-gcc.add: Remove %{_exeext} from gccbug.
* gcc3newlib/gccnewlib.add: Add %gcj to support to disabling building
gcj from rpmbuild command line.
Copy gsyslimits.h for CDN-X compilation.
* Apply the 2003-01-31 changes OAR's broken CVS had dropped.
* gcc3newlib/gccnewlib.add: Remove Buildroot.
* common/.cvsignore: New.
* gcc3newlib/gccnewlib.add: Remove header, broken cdn-X configuration,
%clean, Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/mkspec.in: Remove exe_ext.
* gcc3newlib/target-c++.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gnat.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
+ gcc3newlib/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
* ChangeLog: Fix yesterday's entry.
* gdb/target-gdb.add: %defattr(-,root,root).
Use %{_prefix} instead of /opt/rtems.
Misc. minor changes.
* gdb/gdb.add: Use %{_prefix} instead of /opt/rtems.
Remove stray unpackaged files.
Use %{_defaultbuildroot} instead of hard-coded values.
configure --disable-nls.
Add BuildPreReq: ncurses-devel.
* gdb/base-gdb.add: %defattr(-,root,root).
* gdb/mkspec.in: New.
* gdb/Makefile.am: Reflect addition of gdb/mkspec.in.
* gcc3newlib/mkspec.in: Fix usage.
* gcc3newlib/gccnewlib.add: Use %{_defaultbuildroot} instead of
hard-coded values. Update copyright notice.
* mkgdbspec.in: Removed.
* Makefile.am: Remove mkgdbspec.
* configure.ac: Remove mkgdbspec.
Add gdb/mkspec.
* gccnewlib.add: Add various BuildPreReq.
Add %defattr(-,root,root) to "dir".
* base-g77.add: %defattr(-,root,root).
* base-gcc.add %defattr(-,root,root).
* base-gcj.add %defattr(-,root,root).
* base-gnat.add %defattr(-,root,root).
* target-c++.add %defattr(-,root,root).
* target-g77.add %defattr(-,root,root).
* target-gcc.add %defattr(-,root,root).
* target-gcj.add %defattr(-,root,root).
* target-gnat.add %defattr(-,root,root).
* target-objc.add %defattr(-,root,root).
* setup.def: Updated patch to fix m68k cut and paste bug which turned
a tab into spaces in a Makefile fragment.
* gcc3newlib/gccnewlib.add: If building gnat for the mips, the library
must be built with a -G0 option.
* setup.def, gcc3newlib/gccnewlib.add: Updated to gcc 3.2.1 RPM revision
2 which enabled the mips-rtems gnat using gcc 3.2.1 patch 20021129.
* setup.def: Updated to gcc-3.2 and newlib1.1.0 RPM version 6.
* gcc3newlib/gccnewlib.add: Reenabled i386-rtems gnat.
Remove *.la's to make rpm-4.1/RH-8.0 happy.
Remove libiberty.a to make rpm-4.1/RH-8.0 happy.
Change gcc/version.c to reflect us having patched gcc.
* setup.def, gcc3newlib/gccnewlib.add: Patch includes updates
which were patch changes for -3 and -4 RPM revisions. Disabled
build of gnat for i386-rtems as it failed to build.
* gcc3newlib/gccnewlib.add: Remove %{target} != %{build} comment
(RH-8.0/rpm-4.1 bogusly expands the macros and chokes.)
* binutils/binutils.add: Remove %{target} != %{build} comment
(RH-8.0/rpm-4.1 bogusly expands the macros and chokes.).
Comment out CONFIGURE_ARGS (RH-8.0/rpm-4.1 is broken wrt. _build_os
and _target_os)
* gcc3newlib/base-gcc.add: Add gccint*infos.
* gcc3newlib/base-gcj.add: Add gcj*infos.
Mark manpages as %doc and pickup the gzipped versions.
* setup.def: Update gcc 3.2 pathc to includ epatch for gcc PR8314.
* gcc3newlib/gccnewlib.add: Don't build mips/gnat as we do not
currently include the patch referenced in PR8344.
* gcc3newlib/base-gcj.add, gcc3newlib/gccnewlib.add,
gcc3newlib/target-gcj.add: First attempt at enabling Java support.
* setup.def, gcc3newlib/gccnewlib.add: Updated the tools for
gcc 3.2 and Ada.
* gcc3newlib/gccnewlib.add: Re-add i386-rtems Ada.
Add %_gnat and --define 'gnat [0|1]' support.
Enable gnat for gcc-3.2/Disable for gcc-3.1.
Add hacks to build gnatlib.
Re-activate commented out fragments for old gcc versions.
Add @target_alias@-gnatgcc.
* setup.def: New gcc 3.1 RPMs (-7).
* gcc3newlib/gccnewlib.add: i386-rtems doesn't build Ada.
* gcc3newlib/Makefile.am: Remove c_only remnants.
* gcc3newlib/gccnewlib.add: Reflect gcc-3.2 putting c++
headers into c++ instead of g++.
* gcc3newlib/target-c++.add: Ditto.
* gcc3newlib/base-gnat.add: Don't use %{%prefix}/bin/gnat*.
* gcc3newlib/Makefile.am: Use mkspec for c4x.
* gcc3newlib/gccnewlib.add: Rework processing of %if %build_XXX.
Rework handing Ada.
Don't put adalib and adainclude into files.gcc.
* gcc3newlib/target-gnat.add: Add adalib.
Add adainclude.
* mkgcc3newlibspec.in: Remove
* gcc3newlib/mkspec.in: New.
* gcc3newlib/gccnewlib.add: Add build_XXX defines.
Add preliminary gnat support.
* gcc3newlib/base-g77.add: Add build_g77.
* gcc3newlib/base-gcj.add: Add build_gcj.
* gcc3newlib/base-gnat.add: New.
* gcc3newlib/target-c++.add: Add build_cxx.
* gcc3newlib/target-g77.add: Add build_g77.
* gcc3newlib/target-gcj.add: Add build_gcj.
* gcc3newlib/target-objc.add: Add build_objc.
* gcc3newlib/target-gnat.add: New.
* gcc3newlib/Makefile.am: Use ./mkspec. Use unified spec.
* setup.def: Increment release for gcc3newlib.
* gcc3newlib/gccnewlib.add: Do not put cc1plus into gcc-rpm.
* mkgdbspec.in, setup.def, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Updated to gcc 3.1 and gdb 5.2.
* mkgcc3newlibspec.in: Remove SETUP (bogus).
* gcc3newlib/target-c++.add: New.
* gcc3newlib/Makefile.am: Add target-c++.add.
* gcc3newlib/base-g77.add: Adapt to gcc-3.1.
Reflect having split out c++. Various minor fixes.
* gcc3newlib/base-gcc.add: Ditto.
* gcc3newlib/gccnewlib.add: Ditto.
* gcc3newlib/target-gcc.add: Ditto.
* gcc3newlib/gccnewlib.add: Add gcc_update --touch to fix
timestamps.
* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* gcc3newlib/gccnewlib.add: Add -Bgcc/ when collecting multilibs.
* mkbinutilspec.in: Add support for empty patch-version (no patch).
* mkgcc3newlibspec.in: Ditto.
* setup: Fix gcc3*_versions handling.
* setup.def: binutils_patch_version=.
* binutils/binutils.add: Reflect changes to mkbinutilspec.in,
Use "%{_target_os}" != "%{_build_os}" to detect cross-building.
* binutils/target-binutils.add: Comment out c++filt.
* gcc3newlib/base-gcc.add: Remove duplicate libm.info.
* gcc3newlib/gccnewlib.add: Reflect changes to mkgcc3newlibspec.in.
Comment out gcc-2.95.x hacks.
Remove *.la from installed files.
* gcc3newlib/gccnewlib_c_only.spec.in: Remove.
* Per PR64 added support for gcc 3.x RPMs
* Makefile.am, configure.ac, mkspec, setup, setup.def: Modified.
* mkgcc3newlibspec.in: New file.
* gcc3newlib: New subdirectory.
* base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add,
gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am,
README, target-g77.add, target-gcc.add, target-gcj.add,
target-objc.add: New files.
