* autotools/automake-rtems.spec.in: Automake-1.6.3.
* cpukit/.cvsignore: Add mkspec. Remove rtems.spec.
* configure.ac: Use AC_CONFIG_FILES(script, chmod +x script)
to generate mk*spec scripts.
* mkbspspec.in: Use ',' as pattern delimiter in sed expression
for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed
expression for $rpm_build_root.
* cpukit/mkspec.in: Cosmetical changes.
* ChangeLog: Fix 2002-07-22 ChangeLog entry bogusly referring to
Joel.
* cpukit/Makefile.am: New.
* cpukit/mkspec.in: New.
* cpukit/rtems-cpukit.spec.in: New.
* cpukit/.cvsignore: New.
* configure.ac: Add cpukit.
Add RTEMS_TOP to pickup _RTEMS_VERSION (required by cpukit).
* Makefile.am: Add cpukit. Add ACLOCAL_AMFLAGS (required to pickup
RTEMS_VERSION).
* setup.def: Use %{_tmppath} as default for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed expression
* mkgccnewlibspec.in: Use ',' as pattern delimiter in sed
* mkgcc3newlibspec.in: Use ',' as pattern delimiter in sed
* mkgdbspec.in: Use ',' as pattern delimiter in sed expression for
$rpm_build_root.
