* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -8/+24 |
* | Now binutils, gcc, and gdb build into a "base" package that is shared | Joel Sherrill | 2000-01-25 | 1 | -0/+2 |
| | | | | | | by all targets and one or more target specific RPMs. This significantly reduces the conflicts between the RPMs whether installing one or multiple targets. | ||||
* | Updated list of targets to build. | Joel Sherrill | 2000-01-14 | 1 | -2/+1 |
* | Clean up /opt/rtems in case junk is installed in the wrong place. | Joel Sherrill | 1999-11-02 | 1 | -4/+4 |
| | | | | This has been seen on some machine configurations. | ||||
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 1 | -9/+14 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Shipping this all to Ralf. | Joel Sherrill | 1999-10-21 | 1 | -5/+5 |
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 1 | -14/+23 |
| | | | | functioned. | ||||
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+177 |
