path: root/scripts/buildall.in (follow)
* 2001-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-021-1/+1
| | | | * buildall.in: Correct logic for detecting 0 RTEMS RPMS installed.
* 2001-01-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-301-1/+1
| | | | * buildall.in: Corrected logic for detecting when no RPMs are installed.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-311-2/+2
| | | | | | | * buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am, gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am: Added mips-rtems, updated to include new patches and gcc 2.95.2/newlib 1.8.2 revision 11 RPM.
* Port of RTEMS to the ARM processor family by Eric ValetteJoel Sherrill2000-07-271-1/+3
| | | | | | <valette@crf.canon.fr> and Emmanuel Raguet <raguet@crf.canon.fr> of Canon CRF - Communication Dept. This port includes a basic BSP that is sufficient to link hello world.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-8/+24
* Now binutils, gcc, and gdb build into a "base" package that is sharedJoel Sherrill2000-01-251-0/+2
| | | | | | by all targets and one or more target specific RPMs. This significantly reduces the conflicts between the RPMs whether installing one or multiple targets.
* Updated list of targets to build.Joel Sherrill2000-01-141-2/+1
* Clean up /opt/rtems in case junk is installed in the wrong place.Joel Sherrill1999-11-021-4/+4
| | | | This has been seen on some machine configurations.
* Changes from Ralf with script-19991021-0. He fixed the %filesJoel Sherrill1999-10-211-9/+14
| | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process.
* Shipping this all to Ralf.Joel Sherrill1999-10-211-5/+5
* Moved stuff to rtems subdirectory and made sure the system stillJoel Sherrill1999-10-201-14/+23
| | | | functioned.
* New file.Joel Sherrill1999-10-201-0/+177
