2000-10-31 | 2000-10-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am, gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am: Added mips-rtems, updated to include new patches and gcc 2.95.2/newlib 1.8.2 revision 11 RPM. | |||||
2000-07-27 | Port of RTEMS to the ARM processor family by Eric Valette | Joel Sherrill | 1 | -1/+3 | |
<valette@crf.canon.fr> and Emmanuel Raguet <raguet@crf.canon.fr> of Canon CRF - Communication Dept. This port includes a basic BSP that is sufficient to link hello world. | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -8/+24 | |
2000-01-25 | Now binutils, gcc, and gdb build into a "base" package that is shared | Joel Sherrill | 1 | -0/+2 | |
by all targets and one or more target specific RPMs. This significantly reduces the conflicts between the RPMs whether installing one or multiple targets. | |||||
2000-01-14 | Updated list of targets to build. | Joel Sherrill | 1 | -2/+1 | |
1999-11-02 | Clean up /opt/rtems in case junk is installed in the wrong place. | Joel Sherrill | 1 | -4/+4 | |
This has been seen on some machine configurations. | |||||
1999-10-21 | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1 | -9/+14 | |
issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | |||||
1999-10-21 | Shipping this all to Ralf. | Joel Sherrill | 1 | -5/+5 | |
1999-10-20 | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1 | -14/+23 | |
functioned. | |||||
1999-10-20 | New file. | Joel Sherrill | 1 | -66/+66 | |
1999-10-20 | Generated files removed. | Joel Sherrill | 1 | -55/+87 | |
1999-10-20 | Restored joel's changes after merging old version from Ralf. | Joel Sherrill | 1 | -19/+90 | |
1999-10-20 | New version from Ralf. | Joel Sherrill | 1 | -90/+19 | |
1999-10-20 | Committing changes before Ralf's changed. | Joel Sherrill | 1 | -24/+56 | |
1999-10-19 | Left to build overnight. | Joel Sherrill | 1 | -0/+113 | |
