* binutils/binutils.add: Take out -D_FORTIFY_SOURCE from CFLAGS
to prevent fortify from rendering ar unusable.
* binutils/mkspec.in, gccnewlib/mkspec.in, gdb/mkspec.in:
Use ',' as sed pattern delimiter.
* binutils/base-binutils.add, binutils/binutils.add:
Misc %infodir/dir handling changes.
* binutils/binutils.add: Use BuildRequires instead of BuildPreReq.
* gccnewlib/gccnewlib.add: Use BuildRequires instead of BuildPreReq.
* gdb/gdb.add: Use BuildRequires instead of BuildPreReq.
* gccnewlib/gccnewlib.add: Remove Source0-magic for gcc < 3.0.
* binutils/Makefile.am: Add h8300-rtemscoff.
Remove or32-rtems.
* binutils/binutils.add: Propagate RPM_OPT_FLAGS to configure.
* binutils/base-binutils.add, binutils/binutils.add,
binutils/target-binutils.add: Introduce %{_includedir}, %{_libdir},
%{_bindir}. Remove superfluous %doc. Misc. fixes.
* configure.ac: chmod +x rtems/mkspec.
* binutils/binutils.add: Remove Prefix.
Use mkdir -p.
* cpukit/rtems-cpukit.add: Fix Source URL.
* rtems/Makefile.am: Append @osversion@ to rules.
* rtems/rtems.add: Fix Source URL. Misc cosmetics.
* binutils/target-binutils.add, cpukit/rtems-cpukit.add,
gcc3newlib/gccnewlib.add, gdb/gdb.add, rtemsdoc/rtemsdoc.add:
Remove Autoreqprov-tag.
* setup.def: Update gcc to 3.3.5 and binutils to 2.15.
* autotools/autoconf-rtems.spec.in: Temporarily do not include
some of the documentation since it causes the RPM build to fail.
* binutils/Makefile.am, gcc3newlib/Makefile.am: Add mips64-rtems.
* buildall.in, buildalltar.in, binutils/Makefile.am,
cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/gccnewlib.add,
gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore,
rtemsdoc/Makefile.am: i960 obsoleted.
* binutils/binutils.add: Rename package from binutils-collection to
binutils. Cleanups.
* binutils/target-binutils.add: Reflect changes above.
* binutils/Makefile.am: Add avr. Reflect changes above.
* binutils/Makefile.am: Add sh-rtemscoff.
Remove sh-rtemself.
* binutils/binutils.add: BuildRequires flex.
* autotools/automake-rtems.spec.in: Automake 1.8.5.
* binutils/base-binutils.add: Apply _infodir.
Don't install libiberty. Misc. cleanups.
* binutils/binutils.add: Apply _infodir, _mandir.
Don't install libiberty. Gzip man pages. Misc. cleanups.
* binutils/target-binutils.add: Apply _mandir.
* binutils/base-binutils.add: Preparations for binutils-2.15.
cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am,
gdb/Makefile.am: Attempt to convert all c4x-rtems references to
tic4x-rtems. Left the rtems documentation alone.
rtemsdoc/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* Makefile.am: Cosmetics.
* autotools/Makefile.am: Cosmetics.
* autotools/autoconf-rtems.spec.in: 2.59.
* autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59.
* binutils/Makefile.am: Cosmetics.
* cpukit/Makefile.am: Cosmetics.
* gcc3newlib/Makefile.am: Cosmetics.
* gccnewlib/Makefile.am: Cosmetics.
* gdb/Makefile.am: Cosmetics.
* rtems/Makefile.am: Cosmetics.
* rtemsdoc/Makefile.am: Cosmetics.
* binutils/Makefile.am: Add tic4x.
* binutils/mkspec.in: Remove duplicate rpmgroup.
rtemsdoc/Makefile.am: Obsoleting HP PA-RISC port.
* binutils/base-binutils.add: Add osversion support.
* binutils/binutils.add: Add osversion support.
%setup -n %{name}-%{version}.
Don't remove c++filt.
* binutils/target-binutils.add: Add osversion support.
Pickup c++filt.
* gcc3newlib/base-g77.add: Add osversion support.
* gcc3newlib/base-gcc.add: Add osversion support.
* gcc3newlib/base-gcj.add: Add osversion support.
* gcc3newlib/base-gnat.add: Add osversion support.
* gcc3newlib/gccnewlib.add: Add osversion support.
Remove c++filt,
%setup -n -n %{name}-%{version}.
* gcc3newlib/target-c++.add: Add osversion support.
Don't pickup c++filt.
* gcc3newlib/target-g77.add: Add osversion support.
* gcc3newlib/target-gcc.add: Add osversion support.
* gcc3newlib/target-gcj.add: Add osversion support.
* gcc3newlib/target-gnat.add: Add osversion support.
* gccnewlib/gccnewlib.add: %setup -n %{name}-%{version}.
* gdb/base-gdb.add: Add osversion support, rpmgroup, rpmprefix,
gdb_version, gdb_target.
* gdb/target-gdb.add: Ditto.
* gdb/gdb.add: Ditto.
* binutils/Makefile.am: Fix osversion support for sh-rtemself.
* gcc3newlib/Makefile.am: Fix osversion support for sh-rtemself.
* configure.ac: Add --enable-osversions (OS-versioned RPMS support).
* binutils/Makefile.am: Add osversion support.
* binutils/mkspec.in: Add osversion support.
* gcc3newlib/Makefile.am: Add osversion support.
* gcc3newlib/mkspec.in: Add osversion support.
* gdb/Makefile.am: Add osversion support.
* gdb/mkspec.in: Add osversion support.
Add rpmprefix, rpmgroup.
* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gdb/Makefile.am,
rtems/Makefile.am,
Merger from rtems-4-6-branch.
* common/common.am: New.
* binutils/binutils.add: Preps for 2.14.
Use %{binutils_version} instead of @binutils_version@.
* binutils/base_binutils.add: Preps for 2.14.
* README.cdn-X: New.
* binutils/binutils.add: Add --build=%_build --host=%_host.
* cpukit/.cvsignore: Add *.spec.in.
* gcc3newlib/gccnewlib.add: Add --build=%_build --host=%_host.
* gdb/gdb.add: Add --build=%_build --host=%_host.
* rtemsdoc/.cvsignore: Add *.spec.in.
* common/common.add.in: Add Vendor, Distribution, BuildRoot.
* binutils/Makefile.am: Fix path to clean.add.
* binutils/binutils.add: Remove BuildRoot.
* cpukit/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtems-cpukit.spec.in.
* cpukit/header.add: New.
* cpukit/rtems-cpukit.spec.in: Remove.
* cpukit/rtems-cpukit.add: New.
* gccnewlib/gccnewlib.add: Remove Buildroot.
* gdb/gdb.add: Remove Buildroot.
* rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* gdb/gdb.add: Remove header, broken cdn-X configuration,
%clean, Replace @exe_ext@ with %{_exeext}.
* gdb/mkspec.in: Remove exe_ext.
* gdb/target-gdb.add: Replace @exe_ext@ with %{_exeext}.
* gdb/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* cpukit/mkspec.in: Remove exe_ext.
* binutils/Makefile.am: Use $(top_builddir)/common/common.add,
* binutils/binutils.add: Remove header, broken cdn-X configuration,
%clean.
* binutils/mkspec.in: Remove exe_ext, build_alias, host_alias.
* binutils/target-binutils.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/header.add: New.
* gccnewlib/header.add: New.
* binutils/header.add: New.
* gdb/header.add: New.
* rtemsdoc/header.add: New.
* rtemsdoc/rtemsdoc.add: New.
* common/clean.add.in: New.
* common/common.add.in: New.
* binutils/Makefile.am: Reflect changes above.
* binutils/mkspec.in: New.
* binutils/.cvsignore: Add mkspec.
* mkbinutilspec.in: Remove.
* gdb/Makefile.am: Depend on mkspec.
* binutils/binutils.add: Add @exe_ext@ to c++filt.
Add %_defaultbuildroot.
* setup.def: binutils_rpm_release=2.
* binutils/base-binutils.add: %defattr(-,root,root).
* binutils/binutils.add: Ditto.
* binutils/target-binutils.add: Ditto.
* binutils/binutils.add: Add BuildPreReq: /sbin/install-info.
Disable nls.
Apply gzip -9qf to compress *infos and *mans.
Apply /sbin/install-info.
Remove *c++-filt.
* binutils/base-binutils.add: Add PreReq: /sbin/install-info.
Package as.info-*.gz.
Package man1/*.1*.
* setup.def: Switched to binutils 2.13.1
* binutils/Makefile.am: Remove a29k-rtems.
* gcc3newlib/gccnewlib.add: Remove %{target} != %{build} comment
(RH-8.0/rpm-4.1 bogusly expands the macros and chokes.)
* binutils/binutils.add: Remove %{target} != %{build} comment
(RH-8.0/rpm-4.1 bogusly expands the macros and chokes.).
Comment out CONFIGURE_ARGS (RH-8.0/rpm-4.1 is broken wrt. _build_os
and _target_os)
* gcc3newlib/base-gcc.add: Add gccint*infos.
* gcc3newlib/base-gcj.add: Add gcj*infos.
Mark manpages as %doc and pickup the gzipped versions.
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* binutils/Makefile.am: Add or32-rtems-binutils.
* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* mkbinutilspec.in: Add support for empty patch-version (no patch).
* mkgcc3newlibspec.in: Ditto.
* setup: Fix gcc3*_versions handling.
* setup.def: binutils_patch_version=.
* binutils/binutils.add: Reflect changes to mkbinutilspec.in,
Use "%{_target_os}" != "%{_build_os}" to detect cross-building.
* binutils/target-binutils.add: Comment out c++filt.
* gcc3newlib/base-gcc.add: Remove duplicate libm.info.
* gcc3newlib/gccnewlib.add: Reflect changes to mkgcc3newlibspec.in.
Comment out gcc-2.95.x hacks.
Remove *.la from installed files.
* gcc3newlib/gccnewlib_c_only.spec.in: Remove.
