* | Regenerated | Joel Sherrill | 1999-10-26 | 1 | -5/+6 |
* | Patch generated from scripts-19991025-0.tar.gz from | Joel Sherrill | 1999-10-25 | 2 | -8/+6 |
| | | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages) | ||||
* | Regnenerated following update from Ralf. | Joel Sherrill | 1999-10-25 | 1 | -5/+6 |
* | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 1999-10-25 | 2 | -22/+14 |
* | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1999-10-21 | 1 | -1/+13 |
* | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1999-10-21 | 2 | -1/+2 |
| | | | | | | not right yet. Now can specify rpm_build_root via setup. | ||||
* | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 1999-10-21 | 2 | -39/+48 |
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 3 | -14/+23 |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | ||||
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 1 | -0/+1 |
| | | | | functioned. | ||||
* | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 1999-10-20 | 1 | -2/+3 |
| | | | | Ralf's end of day version. | ||||
* | Generated files removed. | Joel Sherrill | 1999-10-20 | 1 | -7/+13 |
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 3 | -0/+436 |
