* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* mkbinutilspec.in: Add support for empty patch-version (no patch).
* mkgcc3newlibspec.in: Ditto.
* setup: Fix gcc3*_versions handling.
* setup.def: binutils_patch_version=.
* binutils/binutils.add: Reflect changes to mkbinutilspec.in,
Use "%{_target_os}" != "%{_build_os}" to detect cross-building.
* binutils/target-binutils.add: Comment out c++filt.
* gcc3newlib/base-gcc.add: Remove duplicate libm.info.
* gcc3newlib/gccnewlib.add: Reflect changes to mkgcc3newlibspec.in.
Comment out gcc-2.95.x hacks.
Remove *.la from installed files.
* gcc3newlib/gccnewlib_c_only.spec.in: Remove.
* configure.ac: Add AC_PREFIX_DEFAULT([/opt/rtems]).
* mkbinutilsspec.in: Add propagation of @prefix@.
* binutils/base-binutils.add:
Let %post and %unpost apply %{_prefix}.
Apply %{_prefix} instead of /opt/rtems.
* binutils/binutils.add: Update copyright notice.
Add _prefix.
Remove -a 0 in %setup.
Rework hack to SuSE's rpm screwing up %{_target}.
Replace ARGS with CONFIGURE_ARGS.
