* autotools/autoconf.add: autoconf-2.60.
* autotools/automake.add: Add %{?dist}.
* autotools/autoconf.add: Add %{?dist}.
Replace Copyright: by Licence:.
* configure.ac: Reflect changes to autotools/*.
* autotools/Makefile.am: Update.
* autotools/automake-rtems.spec.in, autotools/autoconf-rtems.spec.in:
Remove.
* autotools/automake.add, autotools/autoconf.add,
autotools/header.add: New.
* autotools/Makefile.am: Streamline specs generation with other
tools.
autotools/autoconf-rtems.spec.in: Remove rpm anachronisms.
* autotools/automake-rtems.spec.in: automake-1.9.5.
* autotools/automake-rtems.spec.in: automake-1.9.4.
* setup.def: Update gcc to 3.3.5 and binutils to 2.15.
* autotools/autoconf-rtems.spec.in: Temporarily do not include
some of the documentation since it causes the RPM build to fail.
* binutils/Makefile.am, gcc3newlib/Makefile.am: Add mips64-rtems.
* autotools/autoconf-rtems.spec.in: Cleanup for chroot'ed builds.
* autotools/automake-rtems.spec.in: automake-1.9.2.
* autotools/automake.spec.in: automake-1.9.
* binutils/Makefile.am: Add sh-rtemscoff.
Remove sh-rtemself.
* binutils/binutils.add: BuildRequires flex.
* autotools/automake-rtems.spec.in: Automake 1.8.5.
* autotools/automake-rtems.spec.in: Upgrade to 1.8.4.
* autotools/automake-rtems.spec.in: Upgrade to 1.8.3.
* configure.ac: Enable OS versioning by default for 4.7 branch.
* setup.def: Update binutils RPM version and build new gcc 3.2.3 RPMs.
* autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in:
Update for new tool spin.
* scripts/automake.spec.in: 1.8.2.
* scripts/automake.spec.in: 1.8.1.
Add Patch0 automake-1.8.1-rtems-20040112-1.diff.
Add defattr, URL:-tag.
* Makefile.am: Cosmetics.
* autotools/Makefile.am: Cosmetics.
* autotools/autoconf-rtems.spec.in: 2.59.
* autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59.
* binutils/Makefile.am: Cosmetics.
* cpukit/Makefile.am: Cosmetics.
* gcc3newlib/Makefile.am: Cosmetics.
* gccnewlib/Makefile.am: Cosmetics.
* gdb/Makefile.am: Cosmetics.
* rtems/Makefile.am: Cosmetics.
* rtemsdoc/Makefile.am: Cosmetics.
* autotools/automake-rtems.spec.in: Automake-1.7.8.
* autotools/automake-rtems.spec.in: Automake-1.7.7.
* Makefile.am, configure.ac,
autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in,
binutils/Makefile.am, binutils/base-binutils.add,
binutils/binutils.add, binutils/mkspec.in,
binutils/target-binutils.add,
common/common.add.in,
cpukit/Makefile.am,
gcc3newlib/Makefile.am, gcc3newlib/base-g77.add,
gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add,
gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add,
gccnewlib/Makefile.am,
gdb/Makefile.am,
rtems/Makefile.am,
Merger from rtems-4-6-branch.
* common/common.am: New.
* autotools/automake-rtems.spec.in: Automake-1.7.6.
* autotools/automake-rtems.spec.in: Automake-1.7.5.
* autotools/automake-rtems.spec.in: Update to automake-1.7.2.
* autotools/autoconf-rtems.spec.in: Update to autoconf-2.57.
* autotool/autoconf-rtems.spec.in: Fix @prefix@.
* autotools/automake-rtems.spec.in: Fix my address. Set up PATH
before running configure (Prep. for automake >= 1.7).
* autotools/autoconf-rtems.spec.in: New.
Remove Provides: autoconf (Conflicts with RH-8.0).
* autotools/autoconf-rtems.spec: Remove.
Remove Provides: automake (Conflicts with RH-8.0).
* gcc3newlib/Makefile.am: Remove references to mkgcc3newlibspec.
* Makefile.am: Ditto.
* configure.ac: Add autotools/autoconf-rtems.spec.in.
* autotools/automake-rtems.spec.in: Automake-1.6.3.
* cpukit/.cvsignore: Add mkspec. Remove rtems.spec.
* autotools/automake-rtems.spec.in: Update to automake-1.6.2.
* autotools/automake-rtems.spec.in: Update to automake-1.6.1.
Use *.tar.bz2.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR151
* autotools/automake-rtems.spec.in: New.
* autotools/automake-rtems.spec: Removed.
* mkbinutilsspec.in: Guard sed-pattern against autoconf.
* mkgccnewlibspec.in: Guard sed-pattern against autoconf, remove
Target_alias.
* mkgdbspec.in: Guard sed-pattern against autoconf.
* mkbspspec.in: Guard sed-pattern against autoconf.
* configure.ac: Rework check for RPM_SPECSdir.
* autotools/automake-rtems.spec: Update to automake-1.5.
* autotools/.cvsignore: New file.
* autotools/Makefile.am, autotools/autoconf-rtems.spec,
autotools/automake-rtems.spec: New.
* configure.in, Makefile.am: Add autotools/.
