* | 2002-10-25 Joel Sherrill <joel@OARcorp.com> | Ralf Corsepius | 2002-10-25 | 1 | -0/+88 |
* autotools/autoconf-rtems.spec.in: New. Remove Provides: autoconf (Conflicts with RH-8.0). * autotools/autoconf-rtems.spec: Remove. * autotools/automake-rtems.spec.in: Remove Provides: automake (Conflicts with RH-8.0). * gcc3newlib/Makefile.am: Remove references to mkgcc3newlibspec. * Makefile.am: Ditto. * configure.ac: Add autotools/autoconf-rtems.spec.in. |
