1999-11-30 | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1 | -106/+0 | |
<corsepiu@faw.uni-ulm.de> which converted fiels to automake. | |||||
1999-10-26 | Regenerated | Joel Sherrill | 1 | -1/+3 | |
1999-10-25 | Patch generated from scripts-19991025-0.tar.gz from | Joel Sherrill | 1 | -3/+1 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages) | |||||
1999-10-25 | Regnenerated following update from Ralf. | Joel Sherrill | 1 | -1/+3 | |
1999-10-25 | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 1 | -3/+1 | |
1999-10-20 | Adding the infrastructure for gdb. | Joel Sherrill | 1 | -1/+3 | |
1999-10-20 | New version from Ralf. | Joel Sherrill | 1 | -0/+104 | |
