path: root/scripts/TODO (follow)
* Miscellaneous improvements and cleanups committed so I can mergeJoel Sherrill1999-10-201-0/+6
| | | | Ralf's end of day version.
* New version from Ralf.Joel Sherrill1999-10-201-6/+0
* Working on being able to cut RPMs. It now appears that the processJoel Sherrill1999-10-181-0/+7
is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets.
