path: root/scripts/README (unfollow)
1999-10-18Working on being able to cut RPMs. It now appears that the processJoel Sherrill1-10/+154
is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets.
1999-10-15Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts toJoel Sherrill1-0/+94
help build RPMs.
