* autotools/Makefile.am, autotools/autoconf-rtems.spec,
autotools/automake-rtems.spec: New.
* configure.in, Makefile.am: Add autotools/.
* buildalltar.in: New file.
* configure.in, Makefile.am: Modified to reflect addition of file.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
BSP needs to be eliminated.
issue and has mkbspspec in a better state. user.cfg is now
gone.
There are some miscellaneous changes to buildall done by Joel
to clean up the build process.
functioned.
Ralf's end of day version.
