path: root/scripts/Makefile.am (follow)
* 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-291-1/+2
| | | | | | | | | | | | | | | | | | | | | | * ChangeLog: Fix 2002-07-22 ChangeLog entry bogusly referring to Joel. * cpukit/Makefile.am: New. * cpukit/mkspec.in: New. * cpukit/rtems-cpukit.spec.in: New. * cpukit/.cvsignore: New. * configure.ac: Add cpukit. Add RTEMS_TOP to pickup _RTEMS_VERSION (required by cpukit). * Makefile.am: Add cpukit. Add ACLOCAL_AMFLAGS (required to pickup RTEMS_VERSION). * setup.def: Use %{_tmppath} as default for $rpm_build_root. * mkbinutilsspec.in: Use ',' as pattern delimiter in sed expression for $rpm_build_root. * mkgccnewlibspec.in: Use ',' as pattern delimiter in sed expression for $rpm_build_root. * mkgcc3newlibspec.in: Use ',' as pattern delimiter in sed expression for $rpm_build_root. * mkgdbspec.in: Use ',' as pattern delimiter in sed expression for $rpm_build_root.
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-281-2/+2
| | | | | | | | | | | * Per PR64 added support for gcc 3.x RPMs * Makefile.am, configure.ac, mkspec, setup, setup.def: Modified. * mkgcc3newlibspec.in: New file. * gcc3newlib: New subdirectory. * base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add, gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am, README, target-g77.add, target-gcc.add, target-gcj.add, target-objc.add: New files.
| | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * autotools/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * binutils/Makefile.am: Remove AUTOMAKE_OPTIONS. * gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS. * gdb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-061-1/+1
| | | | | | * autotools/Makefile.am, autotools/autoconf-rtems.spec, autotools/automake-rtems.spec: New. * configure.in, Makefile.am: Add autotools/.
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-301-2/+2
| | | | | * buildalltar.in: New file. * configure.in, Makefile.am: Modified to reflect addition of file.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-16/+8
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-0/+4
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Removed gnat and made final cleanup.Joel Sherrill2000-01-271-3/+0
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-041-0/+1
| | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
* Added first stab at mkgnatnewlib.Joel Sherrill1999-11-041-0/+1
* Changes from Ralf with script-19991021-0. He fixed the %filesJoel Sherrill1999-10-211-2/+0
| | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process.
* Moved stuff to rtems subdirectory and made sure the system stillJoel Sherrill1999-10-201-1/+1
| | | | functioned.
* Miscellaneous improvements and cleanups committed so I can mergeJoel Sherrill1999-10-201-0/+2
| | | | Ralf's end of day version.
* Generated files removed.Joel Sherrill1999-10-201-8/+3
* New version from Ralf.Joel Sherrill1999-10-201-0/+34
